![]() Join Date: Jun 2011
Kouki KA-T Build Thread
***Please move to builds section, sorry for the inconvenience***
Well it has been a while since ive first purchased my 1997 240sx and I figured id post a semi proper build thread since my first post has made much more progress. Well i picked this bad boy up in January of 2012 from a guy in Delaware for 4200 bucks. Stock SE, auto, non abs, 13X,XXX miles 2 owners ... pretty good condition... no rust. And the guy was planning to swap an s14 sr in it so that came home with me too. However upon inspection the SR head was missing all kinds of shit, and honestly wasnt wanting an SR anyway. So I ended up parting that out to help get my 5 speed swap and some coilovers and what i had left to start building a spare KA i had bought locally (ended up being total junk ![]() Build List Engine and Drivetrain: KA24DE All New Gaskets and Seals Bottom end work all done in House at R & W Enterprises -Block Hot Tanked, Baked, Decked, Sleeved, Bored and Honed blah blah blah -Manley Rods -Supertech 9:1 .020+ Pistons -Clevite Main Bearings -Clevite Rod Bearings -ARP Rod Bolts -ARP Main Studs -ARP Head Studs -Crank was micro-polished -Fully Balanced Rotational Assembly Head received a full rebuild and some S13 240/248 cams Timing Chain Water Pump Oil Pump Full 3” HKS Hi Power Exhaust ***Also fabing up a set of custom 3.5" blast pipes Airesearch T3/T4 Hybrid turbo (TO4B compressor housing .60 AR machined to fit TO4E 57 compressor wheel. Turbine is a T3 5 bolt .63 AR machined to stage 3 with a ptrim turbine wheel re-profiled to fit a stage three hole) Oil feed lines CX Racing T3/T4 Top Mount Manifold CX Racing Down Pipe 38mm Tial Wastegate SR 370cc Injectors Precision 880cc Injectors Top Mount Fuel Rail Walbro 255 Fuel Pump HKS SSQV Blow off Valve Custom High Mount Intercooler CX Racing Radiator Dual Slim Fans Z32 MAF HKS Shroom Filter NGK BKR7E Plugs HKS Turbo Timer Enthalpy Tuned ECU 5 Speed Trans RB25DET XTD Lightweight Flywheel RB25DET XTD Stage 3 6 Puck Sprung Clutch Interior: NRG Short Hub NRG Quick Release NRG 350mm Black Suede Red Stitch Wheel Proper Bubble Shift Knob Proper E-brake Knob Glowshift 7 Series Gauges (Oil Pressure, A/F w/ wideband, and Boost) Exterior: Uras Type 4 Rep Front Vertex Rep Sides Vertex Rep Rear 9k Racing Dmax Rep Roof Spoiler GP Sports Rep 3 Piece Trunk Spoiler ***Paint Coming Soon*** (A new twist on Hellrot Red ;P) Morimoto Mini H1 Bixenon Projector Retroquick with Gattling Gun Shrouds in Blacked Out Headlight Housing Suspension/Handling: Function and Form Type 2 Coilovers 10k Swift Upgrade Springs for the Front Godspeed Gen 2.5 Arm Package Project Mu Locking Lugs 17x9+25 17x10.5+20 Mustang Wheels (Black Chrome) 17x8.5 +30 Cobra Wheels +30mm Spacers (Drift Spares) 15mm Spacers Front 10mm Spacers Rear While waiting for some parts in the mail... i got parts in the mail! ![]() So I started to order some parts here and there for the 5 Speed swap since the auto had to go... and plopped that in with the help of my buddy Jake Shoemaker and my buddy AK. Here's how she sat after all that... ![]() Getting to work... (aka a random collection of events and images leading up to today) ![]() ![]() Rods ![]() Supertech Pistons ![]() Poopy Fitment ![]() ![]() Booty Hole ![]() Interesting... ![]() Interior Shot ![]() Bought this stuff and then sold most of it other than some seals and gaskets lol ![]() Blast Pipes (need to add 3.5" chrome slant tips this weekend) ![]() "Clubloose Apparel" and my Autotimer ![]() AK's Fully Built SR Zenki/Thee Garage ![]() KDF Stuff ![]() Stockpiling for shredding season ![]() Morimoto Minis in place of stock projector (much better output imo) ![]() Made some adjustments and got and alignment so she sits pretty... ![]() Dope aristo from the FDR meet (SUPRLIFE) ![]() Shoemakers S13 318rwhp SR ![]() ![]() Spring Moves for some shredding with ^^^ ![]() Got my roof wing in the mail... so i casually put it on my dads corolla while picking it up from home... ![]() ![]() Starting to test fit the kit... ![]() Built motor home for final assembly... ![]() Banishing the demon that put the car out of commission.... Guess that one day when smoke started pouring out of my front vents smelling like burning electrical will do that. Replaced every single harness in the thing. ![]() Built Motor is in for first start and an idea of where im going... ![]() More tomorrow if i have the time ... too tired. Last edited by josh_schul; 04-09-2014 at 10:43 AM.. |
#5 | |
dut in theory you could "sleeve" any block... |
#7 |
Well we have been pretty much at a stand still for a bit. Hopefully selling off some extra bits i have laying around so i can start mocking up intercooler piping and mount up the turbo manifold and start getting her ready for boost. Also will start sanding for paint. Pics this weekend for sure. Got new pads and rotors i need to put on. As well as new struts to replace the blown ones from the craters in Pennsylvania's roads.
First Start (NA) http://instagram.com/p/eicpkAqp1i/ Current shot ![]() |
#9 |
I want a sleeved block myself.. Must have cost alot..
#11 |
how about reading the thread? hes already answered why he sleeved the block..
"Sorry... i guess i should have elaborated... but one of the cylinders was a little iffy after the bore and hone so it was junk a block i had already started to spend money on or buy a new one and do it all again... so I had the trouble cylinder sleeved instead of starting again. R & W has made multiple 700+ blocks for KA24DEs and he insists its his favorite motor next to the 4g63s. Hope that makes sense.. dut in theory you could "sleeve" any block..." |
#12 |
If you read, like ^^^^^ pointed out, you would have known the answer to this.
Anyways 550 cc injectors and some 5 ply elbows and reducers are being 2 day aired to my apt. So hopefully I can run my enthalpy tune for a bit... at least until I order my a gt30 and megasquirt around June or july. Sent from my SAMSUNG-SGH-I537 using Tapatalk |
#14 |
you're going to want at least 740s for a ka-t (or any turbo 4 cylinder) if you want to make decent power.
Watch the enthlapy tune, scott was good but this current dude blows... Had to remap several of those 'pro tuned' ecus for customers just to get the car drivable.
Of all the things I've lost, I truly miss my mind the most. |
#15 | |
build, ka24det, kouki, s14, turbo |
