RB26DETT R32 Motor in parts - trade for other motorset
I got this motor as part of a large trade then tried to trade if for a running RB25DET or RB20DET swap and since have decided to just buy a motor. So I have edited this to a for sale thread. Located in Philadlephia PA. Will take 1300 for everything, I am not parting it out... yet anyhow I rather sell it as the lot..
R32 RB26DETT Bare Block with crank girdle and rear main cover $450 Stock Crank, good clean journals $350 Stock cams $ Sold OEM pistons with connecting rods $120 Timing components -will go with block oil pickup goes - with block GTR oil pan wit diff (no axles or axle seals ) $100 Cylinder head - should be taken apart, cleaned, and new valve stem seals and solid lifters should be reshimmed. I only have about 20 or the 24 OEM shims, but you should be re-shimming anyhow if your building up. $350.00 ECUs $150 for the early R32, $170 for the later R32 Engine harness, coil harness, ignitor, injector harness $ Sold power steering pump (Hicas ) $40.00 Power steer pump bracket RB26 $40.00 OEM turbo piping, tubes, BOV, suction parts $50.00 for the lot add $20 for the BOV's MAFs both for $75 CAS $45 Intake and ITB's and IAC valve (no coolant temp sensors or TPS) $175.00 Ask me about any small parts - Block needs a hone or boring, though there is still some cross hatch. Requires ARP main studs (old owner did not label main bolts in order, and cylinder head should be serviced with shimming (you should be doing this anyhow). I dont have the coil packs, ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by OutToWinPAHC; 09-07-2013 at 06:17 PM.. |
