Old 09-06-2013, 09:00 AM   #1
Psychomoongoose
Psychomoongoose's Avatar
Psychomoongoose is an unknown quantity at this point
Floppy Sun Visor
Anyone have a fix for a floppy sunvisor?
As you can probably guess, like almost every other 240 driver I have coilovers and the ride is a little stiffer than stock. Coupled with 23+ year old sunvisors, it gets a little, ahem, floppy and drops down and generally ticks me off.
Anyone fixed this in their ride? I tried pouring glue down there but to no avail.
Thanks in advance for any permanent solutions.
As long as you're not a ham-fisted retard there shouldn't be a problem.
Psychomoongoose is offline   Reply With Quote
Old 09-06-2013, 09:02 AM   #2
Hiighboost2
Hiighboost2's Avatar
Trader Rating: (32)
Hiighboost2 is an unknown quantity at this point
Feedback Score: 32 reviews
Send a message via AIM to Hiighboost2
Get new sunvisors.
Instagram @hiighboost @iasperformance
Hiighboost2 is offline   Reply With Quote
Old 09-06-2013, 11:10 AM   #3
Psychomoongoose
Would anyone have a part number or could point me to a guide that I could find it in?
Old 09-06-2013, 11:25 AM   #4
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
I highly doubt that actual dealer new sunvisors are still available. You'll have to find a good used set. Your issue is not that common, most 240 sun visors are fine. It shouldn't be a problem finding a good used pair.
Old 09-06-2013, 11:30 AM   #5
Psychomoongoose
Thank you racepar1. You always got the knowledge.
I bought a used one from a reputable guy here on Zilvia, however it has the same issue. I don't really want to keep chucking money on other ones, I would rather fix the one I have.
Old 09-06-2013, 02:17 PM   #6
racepar1
racepar1's Avatar
As far as I know there is no way to take apart the sun visor and tighten up the pivot mechanism. The visor actually clips onto the little 90* rod for the pivot. You can pull it apart and try to wedge something in there. Maybe a thin piece of plastic or maybe a piece of soda can. I MIGHT have a set that's good though. I'll have a look and let you know. It's possible that the clip that holds the inner portion of the sun visor is worn as well. Have you tried another clip, or just the visor itself???
Old 09-06-2013, 06:25 PM   #7
az_240
az_240's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
The arm piece that fits inside the visor is probably worn. You could pull those pieces out and try wrapping the part that fits into the visor with teflon or electrical tape or like racepar said wedge something in there to tighten it up if you can't find a good used set. I was going to try something like this to get my S15 sun visors to work on my S14.
Old 09-06-2013, 06:38 PM   #8
Chaluska
Chaluska is an unknown quantity at this point
My sunvisors flop down when i get above 75 in my vert... stupid things
I have removed said sunvisors.
Chaluska is offline   Reply With Quote
Old 09-06-2013, 06:43 PM   #9
2iv0 sx
2iv0 sx's Avatar
2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute
Same thing happens to my passenger side visor..
I just spank it back up. It does it annoying sometimes as it flaps in my peripherals but at least my spanking is on point now though
2iv0 sx is offline   Reply With Quote
Old 09-09-2013, 08:58 AM   #10
Psychomoongoose
I have only tried a different visor, to no avail. Tonight I will pull it apart and see if I can get the little 90* arm taped up or something smooshed in there to try to get some action on the thing.
Thanks Racepar!
Old 09-09-2013, 09:09 AM   #11
g35gabby
g35gabby's Avatar
Trader Rating: (26)
g35gabby is an unknown quantity at this point
Feedback Score: 26 reviews
I have the same problem with my driver's side.... I believe mostly due to the garage door opener that is attached to it.
I have a spare brown pair I can sell ya if you are interested.
g35gabby is offline   Reply With Quote
Old 09-09-2013, 09:47 AM   #12
h2v7
h2v7 is an unknown quantity at this point
Velcro[][]
h2v7 is offline   Reply With Quote
Old 09-09-2013, 10:52 AM   #13
babyjesus
babyjesus's Avatar
babyjesus is an unknown quantity at this point
the problem is that this circled red thing (you can pull it out of the visor) is worn down or not a tight fit anymore.
what i did was pull it out and wrap it in electrical tape. i should say however to make wrap it as thin as possible, one way around should do it. wrapping it in multiple layers will cause it to not go back in, or take off the tape you just put on. ...once wrapped, squeeze it back in and it'll hold just fine in any position.
might seem like a janky idea, but it fuckin' works.
thelittlebigblock.blogspot.com
babyjesus is offline   Reply With Quote
Old 09-09-2013, 11:04 AM   #14
Psychomoongoose
Okay, this looks like the thing to do. I will give this a shot and reply with the results.
Old 09-09-2013, 11:05 AM   #15
Driftwire
Driftwire's Avatar
Driftwire is an unknown quantity at this point
I have a good set that I will not be putting back in my car since my windsheild is tinted 11 inches down with 2%
Originally Posted by Hoffman5982 View Post
Did you check the potato fuse located in the front right corner of your gas tank?
Originally Posted by RB33 View Post
No i haven't. To be honest i didnt know there was a fuse there. Thats not a fuse for the fuel pump is it?
Driftwire is offline   Reply With Quote
Old 09-09-2013, 11:22 AM   #16
Om1kron
Om1kron's Avatar
Trust me, enjoy your floppy sun visors. I have some damn near new ones in my car and they're a fucking BITCH to move to the window. I'm afraid they're going to break every time I use them.
Wayne Edwards
https://om1kron.blogspot.com
floppy sunvisor, sun visor, sunvisor
