Old 09-12-2013, 10:10 AM   #1
supasan
supasan is an unknown quantity at this point
ka24de rethreading exhaust manifold
How would I rethread the egr pipe hole on the exhaust manifold, if possible. I guess mine stripped somehow when I loosened it, or when I tried putting it back on. Anyway the hole is fairly large so would it be better to just buy a used oem exhaust manifold?
supasan is offline   Reply With Quote
Old 09-12-2013, 10:16 AM   #2
Mikester
Mikester's Avatar
You could try retapping it.
Old 09-12-2013, 10:34 AM   #3
dawagarage
dawagarage's Avatar
dawagarage is an unknown quantity at this point
you could just put the male end in the female end and then use something like epoxy/jb weld/similar if all else fails.
formerly known as "hotboiblaze"
ratsun: dawa (73 datsun 620)
clublexus: properD (97 sc300)
dawagarage is offline   Reply With Quote
Old 09-12-2013, 10:41 AM   #4
supasan
I don't even know the size I would need to retap it. I never thought about using jb weld on it. My first thought was fuck now I gotta buy an exhaust manifold. Thanks. I will keep that in mind.
Old 09-12-2013, 10:54 AM   #5
mewantkouki
Trader Rating: (36)
mewantkouki will become famous soon enoughmewantkouki will become famous soon enoughmewantkouki will become famous soon enough
Feedback Score: 36 reviews
Or delete your egr like everyone else on this site. lol
mewantkouki is offline   Reply With Quote
Old 09-12-2013, 11:19 AM   #6
supasan
I need smog lol. I took the egr system out to clean it cause my nox was almost 3000 at 15mph.
Old 09-12-2013, 11:49 AM   #7
s14boy
Trader Rating: (26)
s14boy is an unknown quantity at this point
Feedback Score: 26 reviews
weld a new nut on the manifold
-Mike
s14boy is offline   Reply With Quote
Old 09-12-2013, 12:08 PM   #8
Mikester
Mikester's Avatar
Originally Posted by supasan View Post
I need smog lol.
That's the spirit!
Old 09-12-2013, 12:27 PM   #9
Driftwire
Driftwire's Avatar
Driftwire is an unknown quantity at this point
I would just Jb weld it and call it a day.
Originally Posted by Hoffman5982 View Post
Did you check the potato fuse located in the front right corner of your gas tank?
Originally Posted by RB33 View Post
No i haven't. To be honest i didnt know there was a fuse there. Thats not a fuse for the fuel pump is it?
Driftwire is offline   Reply With Quote
Old 09-12-2013, 01:05 PM   #10
supasan
Yeah I'm gonna stop by an auto parts store on the way home and pick up some jb weld.
Old 09-12-2013, 01:12 PM   #11
Mikester
Mikester's Avatar
^^There is stuff that holds up even better on exhaust components called Liqui-Steel. Should suit your needs nicely.
Old 09-12-2013, 01:31 PM   #12
supasan
I can't post the pic but is it called liquid metal filler. Thats what I found when I searched on google
Old 09-12-2013, 01:44 PM   #13
supasan
I've just been told that putting jb weld on the manifold will catch on fire...what that liquid metal filler.
Old 09-12-2013, 03:54 PM   #14
dawagarage
dawagarage's Avatar
when you go to the parts store, the max operating temp of the fillers/etc should be on the package
Old 09-12-2013, 04:17 PM   #15
supasan
What temp would be best on the manifold.
Old 09-12-2013, 04:49 PM   #16
Chaluska
Chaluska is an unknown quantity at this point
id make sure it can take at least 1000f
Chaluska is offline   Reply With Quote
Old 09-12-2013, 05:05 PM   #17
supasan
High temp exhaust sealant- PERFECT for turbo manifolds
something along these lines?
Old 09-12-2013, 05:15 PM   #18
mechanicalmoron
mechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nice
JB weld will probably work for a while, but bake out and crumble. If you just need it to pass smog, it will probably work for that long.
See if you can get a muffler shop to weld the right size nut on.
mechanicalmoron is offline   Reply With Quote
Old 09-12-2013, 05:39 PM   #19
supasan
I heard jb weld catches on fire. I guess he experienced it. I need it more than smog lol. Either seal it, weld it, re-thread or buy another manifold.
Adhesives, Applicators, Heat, & Glue Guns | Caulk, Sealants, & Adhesives | VersaChem® Exhaust System Joint Sealer, 00160, 5 Oz. | B967578 - GlobalIndustrial.com
I might get this.
Old 09-12-2013, 06:21 PM   #20
Chaluska
No... JB weld melts when it gets too hot.
Old 09-12-2013, 07:46 PM   #21
supasan
Well I've been misinformed. Anyway I'm gonna try the versa chem sealant and see if it'll hold temporarily
Old 09-12-2013, 08:54 PM   #22
s14boy
Trader Rating: (26)
fix it right and weld a nut(or the correct bung for best results) on it like I stated before a muffler shop would charge less then 10 if you just took them the manifold and nut and had it ready to go. yes I agree you can put some metal miller and call it a day but what happens when you need to remove the pipe again.
Old 09-12-2013, 11:45 PM   #23
supasan
Yeah that is true. I'll take the manifold apart and take it to an auto parts store to find the correct nut tomorrow morning since I don't have school.
Old 09-13-2013, 12:14 AM   #24
dawagarage
dawagarage's Avatar
in a perfect world that would be the primary solution... but the world is imperfect.
i needed just a few tacks worth of welding on a broken exhaust pipe and the shop charged me $60 to stick weld it! (after shopping around)
