Old 09-16-2013, 02:52 PM   #1
mnsmith293
mnsmith293 is an unknown quantity at this point
Code 34 s13 ka24de
The car is a 1992 240sx with a used motor that was put in about 6 months ago. It has never ran quite right and I am trying to get it running correctly. There had no check engine light on so I didn't think to pull the codes until now.
It came up with code 34 and that is it. I was wondering if it could be a false positive, my car has solid poly urethane motor mounts? Will this put the car into limp mode?
Currently the motor starts up easily and cruises well with no smoke. However when I am accelerating sometimes it will bog a little or lag and then catch and start accelerating. The car has no AIV, charcoal canister or cat. Cone filter and crappy 2 inch catback (the old one broke off lol). New: Spark plugs gapped properly, plug wires, distributer cap and rotor, fuel filter, air filter, new oil filter and 10w30.
It does make a ticking sound once with each motor revolution but I think that is lifter tick but I am not sure. I am getting a compression tester today and I will post the results. How would I tell if what the ticking sound is and please help me fix this bogging it is driving me nuts.
mnsmith293 is offline   Reply With Quote
Old 09-16-2013, 03:56 PM   #2
mnsmith293
Also the bogging only happens right around 2700 rpms and will only do it for a split second most of the time or not at all and only at about a quarter throttle (Wot it will not do it) but sometimes it is more noticeable seemingly at night when it's cooler outside. I just went outside to make a video of the car but the ticking was inaudible and it only bogged once for about a half a second and you really couldn't notice it on the video.
Old 09-16-2013, 04:11 PM   #3
coupesallday!
coupesallday!'s Avatar
Trader Rating: (18)
coupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the rough
Feedback Score: 18 reviews
Send a message via MSN to coupesallday!
I heard nicoclub has some great info
Throw some glitter flake and crazy glue in there.
coupesallday! is offline   Reply With Quote
Old 09-16-2013, 04:45 PM   #4
mnsmith293
I read all of the stickys and at first I thought it might be IACV but my idle is fine it idles at 1100 when cold and then settles down to normal very quickly.Please excuse the trunk rattle, this is the car on startup. No ticking is audible just trunk rattle.
http://www.youtube.com/watch?v=nvkSH2wWHmk
And acceleration no lag at all today.
http://www.youtube.com/watch?v=5zdwU0Uzcgc
Old 09-16-2013, 04:47 PM   #5
Om1kron
Om1kron's Avatar
blah the fuck blah, search button.
Wayne Edwards
https://om1kron.blogspot.com
Old 09-16-2013, 04:52 PM   #6
mnsmith293
I've been searching, I managed to swap the engine and get it running all on my own with liberal use of the search button, I just need help with this minor issue.
Old 09-17-2013, 07:58 AM   #7
OnTheChip
OnTheChip's Avatar
OnTheChip is an unknown quantity at this point
Code 34 is the knock sensor, which causes the timing to be retarded for safety, which may be causing the bog issue. Check the knock sensor wiring and replace the knock sensor if necessary.
OnTheChip is offline   Reply With Quote
Old 09-17-2013, 08:46 AM   #8
freepunk
freepunk's Avatar
freepunk is making a name for him/her selffreepunk is making a name for him/her self
Had the same code thrown along with a maf error code. Took weeks to figure out. Ended up being a short in my fuel pump wiring inside the gas tank that was throwing all the codes. Also had bogging issues. I would check all your harneses.
If you do replace the knock sensor it is also a good idea to do the harness sensor at the same time.
freepunk is offline   Reply With Quote
Old 09-17-2013, 10:41 AM   #9
Om1kron
Om1kron's Avatar
don't bother replacing the knock sensor. ditch it entirely and plug it up with a diode. There is information on how to put a 1mhz 1ohm sensor in place of the knock sub harness. this will alleviate that as a problem.
If your engine is going to knock, it's gonna knock. That sensor isn't going to do shit to save it.
Wayne Edwards
Old 09-17-2013, 07:10 PM   #10
mnsmith293
I forgot to mention that I already knew that code 34 = knock sensor. Harness is beyond shit from the previous owner, I didn't notice it at first but the more work I do on the car the more splices and electrical tape I find Thanks for the help guys looks like some electrical work might be in order and deleting the knock sensor.
Found this as well.
"Solid motor mounts/worn broken motor mounts will/can make a solid connection to your chassis causing extreame vibrations at idle and low rpms. Normally the stock mounts dampen this.
Our knock sensors should pick up on these vibrations and retard timing. This will make your car "slower than it was."
