Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Electronics
Old 09-17-2013, 09:54 AM   #1
StreetRacerMotorSports
StreetRacerMotorSports's Avatar
StreetRacerMotorSports is an unknown quantity at this point
Genuine Walbro 400 Series Fuel Pump
Store Wide 5% off use code (5OFF)
Universal Intall Kit
$171.01 Shipped in US
Pump Design
The new 39/50 DCSS pump has been designed around the proven 39mm armature ("motor") that has been used for many years, Coupled with the proven armature are two sets of turbine blades set in paralled on a single impeller shaft. This design allow fuel to pass through two high pressure pumping channels delivering fuel in a manner to work with the high pressure demand of today's direct injection system.
Technical Pump Specifications
Overall pump lehgth: 121mm
main Housing Dia.: 39mm
Lower Housing Dia.: 50mm
Fuel inlet Dia.: 11mm OD
Fuel Outlet Dia.: 11mm OD
Flow rate: 400LPH @ 40PSI
Test Voltage: 13.5 Volts
Proven Design
- A design use in multiple OEM application for years.
- Built to stringent OEM standards.
- Desing around the proven 39mm arnature used for many years.
- Quiet running while achieving substantial fuel flow in comparison to other single stage turbine pumps on market today.
- Ability to function with a greater range on conventinoal powertrains present in today's automotive performance market place.
- Proven to work in the Pulse Width Modulation and Voltage cvarting system present in today's automotive performance market place.
Hot Fuel Handling
Hot fuel testing results show the proven design of the 39/50 DCSS, the pump performed exceptionally well in comparsion to other single stage turbine design pumps on the market today. When tested at a temperature of 153F other single stage pumps on the market showed losses of 12% to 32% in fuel pressure and flow in comparsion to the 39/50 DCSS which only showed a 5% reduction in fuel pressure and flow.
Universal Install Kit
$177.07 Shipped in US
- Outperforms all current market in-tank fuel pumps
- Designed for engines with more than 500 HP
- Award-winning OE technology
- High-pressure, high-flow performance
- OEM technology designed and developed for E85. All pumping components have been validated to OEM specifications for approved use in E85/flex fuel applications.
Note: Requires modificiations to wiring, fuel lines and fuel module
Professional installation recommended
Walbro 400 E85 Flow Chart
Walbro 400 Gasoline Flow Chart
StreetRacerMotorSports is offline   Reply With Quote
Old 09-17-2013, 11:30 AM   #2
s14boy
Trader Rating: (26)
s14boy is an unknown quantity at this point
Feedback Score: 26 reviews
hey could you post a flow sheet for the pump. that would be very helpfull and aid in sales
thanks
-Mike
s14boy is offline   Reply With Quote
