Old 09-23-2013, 01:11 PM   #1
Djmayle
Djmayle is an unknown quantity at this point
Rear Axel Hopping
I have a welded diff on my 1990 240sx. When I'm making turns I feel like my ass end is hopping all over, not like the normal shim from the tires. I lifted it up yesterday and all my subframe bolts are tight and replaced my tires. Does anyone know what it may be?
Djmayle is offline   Reply With Quote
Old 09-23-2013, 02:19 PM   #2
s14boy
Trader Rating: (26)
s14boy is an unknown quantity at this point
Feedback Score: 26 reviews
... its your welded diff i would recommend taking it out for a stock one or go read up about a welded diff before you crash it.
-Mike
s14boy is offline   Reply With Quote
Old 09-23-2013, 03:14 PM   #3
Djmayle
But I'm used to the feeling of the welded diff. This is different, it's more aggressive. Imagine a welded diff with 5x the violence. It just started 2 days ago after I was putting it sideways more than usual. I'm just confused.
Old 09-23-2013, 04:11 PM   #4
PrimeDirective
PrimeDirective's Avatar
PrimeDirective is an unknown quantity at this point
Is your subframe cracked?
PrimeDirective is offline   Reply With Quote
Old 09-23-2013, 04:17 PM   #5
boxerpicker
boxerpicker is an unknown quantity at this point
you have solid diff and subframe bushing? if so then youre fine. its pretty normal
boxerpicker is offline   Reply With Quote
Old 09-24-2013, 02:08 AM   #6
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
Go get a replay/gopro/your phone and stick it up under there and see if you can record what's going on. You say your subframe is good, what about the rest of your suspension? You were drifting after all, something could be loose or bent.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 09-24-2013, 02:59 AM   #7
driftminds13
driftminds13 is an unknown quantity at this point
Check your subframe bushings, axles, rear control arms etc. Something back there is in need of replacing/changing/fixing. As they mentioned above, do you have solid subframe bushings?
driftminds13 is offline   Reply With Quote
Old 09-24-2013, 06:10 AM   #8
thefro526
thefro526's Avatar
thefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of light
Like everyone else said above, check your subframe bushings. Having a welded diff will accelerate the wear of those bushings, especially if you're beating on the car, once they fail, you lose the (relatively) smooth 'chirp' of a welded diff and it's replaced with more of a clunk.
If your bushings are good, then check everything else, bushings, arms, bolts, etc. It could also be that one of your axles is loose or going bad, my two way was 2x louder, if not worse, when one of the axle nuts had come loose.
thefro526 is offline   Reply With Quote
Old 09-24-2013, 10:05 PM   #9
ShadowMan
ShadowMan's Avatar
ShadowMan is an unknown quantity at this point
The Ultimate Guide to Suspension and Handling: Part Six, Adding Negative Camber
If you have your stock/rubber bushings, chances are they've taken a beating and this bushing deflection is part of your problem (page 2, top picture), but it could be any combination that anyone has mentioned above. The idea of mounting a camera under there is a good idea, that or get on a creeper and have a friend tow you around while you look at it from underneath. J/K, don't do that.
in any situation....thou shalt blaze
ShadowMan is offline   Reply With Quote
