Old 09-25-2013, 12:00 PM   #1
S13alldayyo
S13alldayyo's Avatar
S13alldayyo is an unknown quantity at this point
Cody ace ac bracket need help
This is for a s13 compressor to s13 sr everything is s13 including the lines, anyways does anyone have pictures of there s13 to s13 ac installed? (We're the ac compressor is) everything mounts up perfect ANd belt lines up perfectly, only problem I'm having is install the line that goes behind the motor, the valve site right I front of the intake elbow on the turbo. I thought this would be plug an play but was wrong? Any easy quick fixes? Or wil I have to get a welder
S13alldayyo is offline   Reply With Quote
Old 09-25-2013, 12:07 PM   #2
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
It's called Google, Florida.
For Sale #1 | For Sale #2
Old 09-25-2013, 12:12 PM   #3
ultimateirving
ultimateirving's Avatar
I had to get my lines custom made because i used fittings from the dohc a/c system, and i have an sohc chassis. The welder that made my lines fit them around the exhaustmanifold and turbo so they didnt interfere with each other.
Z32 with lq4 swap
Old 09-25-2013, 12:28 PM   #4
S13alldayyo
I've tried google and google pictures, found nothing even Cody himself has no idea. Keep the Florida comments to yourself please. Doesn't make you sound any smarter. And everything I have is DOHC including lines
Old 09-25-2013, 12:46 PM   #5
ultimateirving
if the lines dont reach, then get someone with a tig to extend them. Dont ask me how they do it i PAID them money for that.
Z32 with lq4 swap
Old 09-25-2013, 12:54 PM   #6
S13alldayyo
It does reach, it's just the valve sits I front of the intake elbow on the turbo, so I can't bolt up my intake piping
Old 09-25-2013, 01:33 PM   #7
Mikester
Mikester's Avatar
I did the CodyAce S13 SR to DOHC S13 compressor mod... My work computer is slow as molasses, so I cant upload pics atm... but click HERE to see how I ran mine. Also, regarding the line that goes from the compressor to the firewall... I can see how that line behind the motor would be a PITA. It was easy for me because I deleted all of the heater/coolant lines between the motor & firewall so that AC line is literally the only thing back there.
Also, by the turbine- I use an aftermarket water neck adapter, turbine outlet flange, suction kit etc and it all clears nicely.
If anything, it may give you an idea for some things to try. You didn't post any pics- But you may not even need a welder- It could just be as simple as running a reclock adapter to change the inlet pipe position enough for it to clear. Without seeing; I couldn't really tell ya.
Old 09-25-2013, 01:42 PM   #8
S13alldayyo
Can't post up pics on my iPhone but the problem isn't behind the motor it's just the valve that's in front of the elbow, not sure if I have to cut it off and move it somewhere else.
Old 09-25-2013, 02:12 PM   #9
Mikester
Mikester's Avatar
If I were you, I'd have the inlet 'notched' & re-welded to clear before messing with the AC line; but that's just me.
Old 09-25-2013, 02:13 PM   #10
rellik27
rellik27 is an unknown quantity at this point
I had to unbolt the line from the firewall and gently bend it enough so the valve wouldn't hit the turbo. I don't know if that's what you mean post pics when you can. If anything you could just relocate the valve like you said.
rellik27 is offline   Reply With Quote
Old 09-25-2013, 02:15 PM   #11
S13alldayyo
How can you bend that line? I tried and it's too hard, idk if to reclining or move valve, I have a nice pbm intake don't wana mess the routing
Old 09-25-2013, 02:15 PM   #12
S13alldayyo
Idk if to reclock*
Old 09-25-2013, 02:39 PM   #13
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
STUPID IDEA:
Why don't you contact Codyace? You know, the guy who MADE the bracket...
Old 09-25-2013, 02:43 PM   #14
WristWork
WristWork's Avatar
WristWork is an unknown quantity at this point
Originally Posted by racepar1 View Post
STUPID IDEA:
WristWork is offline   Reply With Quote
Old 09-25-2013, 02:56 PM   #15
jamg
hooked on phonics worked for me too
Old 09-25-2013, 02:57 PM   #16
S13alldayyo
If you would of have read, I already contacted Cody and he said he has no idea
Old 09-25-2013, 02:58 PM   #17
S13alldayyo
So yeah, that would be a pretty STUPID IDEA.
Old 09-25-2013, 03:02 PM   #18
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
I have dohc lines and the codyace kit and it went together smoothly.
Old 09-25-2013, 03:04 PM   #19
racepar1
racepar1's Avatar
Yeah, I'm going to waste my time reading every single part of every single post. That information SHOULD have been included in the OP, since it is EXTREMELY relevant...
Next stupid idea:
PICTURES...
That would likely help in finding your solution a LOT. Just because you SAY that you've got all the "correct" DOHC A/C components does not make it so. A picture is worth a thousand words as the saying goes...
Old 09-25-2013, 03:05 PM   #20
racepar1
racepar1's Avatar
EXACTLY my point...
Plenty of others have too.
Old 09-25-2013, 03:11 PM   #21
S13alldayyo
I have no PC access I can only send pics via txt or email
Old 09-25-2013, 03:12 PM   #22
zooopreme
Trader Rating: (38)
If you wanted quick answers, you would have made the thread WITH pictures. What makes you even more stupid and without common sense would be the fact that iPhones allow for you to download an app to which you can post pictures if you're really impatient.
Others have this kit and it's a bolt on affair. You are not special in a positive way. You've hit a dead end and you want to be spoon fed answers without properly presenting the question? THAT's why I brought up Florida. Because the lack of resourcefulness with the given resources are so under utilized.
Old 09-25-2013, 03:27 PM   #23
racepar1
racepar1's Avatar
Yeah, because you can't upload to photobucket via mobile right???
Oh, wait, YES YOU CAN!!!
YAY! You get it!
It pisses me off to no end to see people posting threads looking for answers but they can't even take the time out of their precious day to be thorough. ALL relevant information SHOULD be in the OP. Said information SHOULD be presented in a concise, organized manner. Pictures SHOULD be included if it will significantly help the rest of us determine what's wrong, which is almost always.
If you half-ass the thread, you're going to get half-assed answers...
Old 09-25-2013, 03:33 PM   #24
S13alldayyo
What app can I use to post pictures I just bolted it all up again and took pictures
Old 09-25-2013, 03:35 PM   #25
S13alldayyo
Found the app I will post pictures in a second
Old 09-25-2013, 03:43 PM   #26
S13alldayyo
ImageUploadedByTapatalk1380145341.736198.jpgImageUploadedByTapatalk1380145353.870068.jpgImageUploadedByTapatalk1380145362.276941.jpgImageUploadedByTapatalk1380145368.869891.jpg
Thanks for letting me know about this app.
Sent from my iPhone using Tapatalk - now Free
Old 09-25-2013, 03:51 PM   #27
ultimateirving
Carefully bend it and massage it so that the nipple is facing away.
Z32 with lq4 swap
Old 09-25-2013, 03:57 PM   #28
S13alldayyo
That really hard to bend...
Old 09-25-2013, 03:59 PM   #29
racepar1
racepar1's Avatar
I've actually run across that issue myself the one time I used Cody's brackets on a car I swapped. I went to an A/C shop and had a custom line made. It was only like $100 or so. You can try to bend it, but that tubing is pretty damn thick and will be difficult to bend without damaging it. Maybe with some precisely and carefully applied heat you could get it.
You can also get R134 conversion fittings that are bent 90*. That might help a little with clearence, though it would still require at least some bending.
Old 09-25-2013, 04:05 PM   #30
S13alldayyo
What a waist, might as well used the sr20det compressor.
