Old 09-26-2013, 02:04 PM   #1
jeedriftbetta
jeedriftbetta's Avatar
jeedriftbetta is an unknown quantity at this point
Exclamation s 13 running rich
hey guys looking for help to fix my s13. i have an sr20det and my coupe is rinning rich on boost. any time i try to puch it to take off it looses power and you can say it gets clogged and i have to shift gear for it in order to run. when ever i punch it to take off it pulls back between 4000 and 5000 rpm. its killing me on gas and more because i use it ass my daily. o hope you guys can help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
jeedriftbetta is offline   Reply With Quote
Old 09-26-2013, 02:25 PM   #2
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Feedback Score: 18 reviews
How do you know you are running rich?
Do you have a wideband installed?
What are your a/f ratios?
Dboyizmlg is offline   Reply With Quote
Old 09-27-2013, 10:22 AM   #3
jsu1012
jsu1012's Avatar
jsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to beholdjsu1012 is a splendid one to behold
^what he said. We need more info.
@streetstyle_jay
jsu1012 is offline   Reply With Quote
Old 09-28-2013, 04:15 AM   #4
jeedriftbetta
No wide band. How can I get the a/f ratio. I know its running rich because it is not burning my gas, every time I drive it it smells like gas. I also took it to the shop and they cant find the problem, they told me that its a mixture if little problems that is causing my car to run rich.i just dont know what the problem might be! How can I find the issue?
Old 09-29-2013, 02:35 PM   #5
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
You need a wideband so you can determine where you're A/f ratios are at.
If you smell gas while you drive, then you should starts looking for fuel leaks. Might want to start with the fuel hose at the fuel filter, and fuel lines around that area. Also, take a look at the injectors some times the O-rings go bad, and leak fuel on the intake manifold.
If all else fails, try replacing you're O-ring on the fuel pump cover (gas tank).
It maybe coming from there also.
It's pretty easy to determine a leak.
Sounds like the shop you took it to, didn't really know what they were doing.
If you are NOT burning enough gas then I would think that would cause it to be Lean. (Not rich).
Look for fuel leaks, fix that first then go from there.
Tune up might help
