Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Electronics
Old 09-27-2013, 10:16 AM   #1
StreetRacerMotorSports
StreetRacerMotorSports's Avatar
StreetRacerMotorSports is an unknown quantity at this point
AEM & Walbro Intank Peroformance Fuel Pumps
Store Wide 5% off use code (5OFF)
Universal Intall Kit
$171.01 Shipped in US
Pump Design
The new 39/50 DCSS pump has been designed around the proven 39mm armature ("motor") that has been used for many years, Coupled with the proven armature are two sets of turbine blades set in paralled on a single impeller shaft. This design allow fuel to pass through two high pressure pumping channels delivering fuel in a manner to work with the high pressure demand of today's direct injection system.
Technical Pump Specifications
Overall pump lehgth: 121mm
main Housing Dia.: 39mm
Lower Housing Dia.: 50mm
Fuel inlet Dia.: 11mm OD
Fuel Outlet Dia.: 11mm OD
Flow rate: 400LPH @ 40PSI
Test Voltage: 13.5 Volts
Proven Design
- A design use in multiple OEM application for years.
- Built to stringent OEM standards.
- Desing around the proven 39mm arnature used for many years.
- Quiet running while achieving substantial fuel flow in comparison to other single stage turbine pumps on market today.
- Ability to function with a greater range on conventinoal powertrains present in today's automotive performance market place.
- Proven to work in the Pulse Width Modulation and Voltage cvarting system present in today's automotive performance market place.
Hot Fuel Handling
Hot fuel testing results show the proven design of the 39/50 DCSS, the pump performed exceptionally well in comparsion to other single stage turbine design pumps on the market today. When tested at a temperature of 153F other single stage pumps on the market showed losses of 12% to 32% in fuel pressure and flow in comparsion to the 39/50 DCSS which only showed a 5% reduction in fuel pressure and flow.
Universal Install Kit
$177.07 Shipped in US
- Outperforms all current market in-tank fuel pumps
- Designed for engines with more than 500 HP
- Award-winning OE technology
- High-pressure, high-flow performance
- OEM technology designed and developed for E85. All pumping components have been validated to OEM specifications for approved use in E85/flex fuel applications.
Note: Requires modificiations to wiring, fuel lines and fuel module
Professional installation recommended
$95 Shipped US Priority
AEM High Flow In-Tank Fuel Pump Features:
Designed for high output naturally aspirated and forced induction EFI vehicles
In-Tank design
Tested to flow 320 lph @ 43 PSI
39mm diameter fits most applications
Offset inlet design eases installation
Each pump individually tested
For gasoline vehicles (pump life may be diminished when used with E85 fuel)
Kit includes fuel pump, rubber sleeve and end caps, pre filter, hose, clamps and flying lead
$120 Shipped US Priority
Tested and compatible with ethanol fuels up to E100, methanol fuels up to M100 and all types of gasoline
In tank design
Each pump is tested to flow 320 lph @ 43 PSI
$187.23 Shipped
OVERVIEW
AEM’s legendary Wideband O2 Air/Fuel UEGO Gauge unites unsurpassed accuracy, speed and control with an easy to read, digital interface. This gauge-type controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere. All AEM digital gauges feature a 0-5v analog output for use with data loggers and virtually any engine management system, such as the AEM EMS or FIC.
$359 Shipped
WHY YOU WANT ONE
The AEM Water/Methanol Injection System comes loaded with more STANDARD features and high quality components than any other comparably priced injection system on the market today. The AEM injection kit comes with a 1 gallon tank with built-in low level indicator. The "Boost Safe" injection readiness system is standard in all AEM Water/Methanol Injection Systems. An integrated check valve in the nozzle prevents unintended fluid flow. One injector and two interchangeable nozzles are included to cover a wide range of potential horsepower levels and 20 feet of injection tubing facilitates installation on almost any vehicle.
PRODUCT FEATURES
1 Gallon tank with built in low level switch
Boost referenced progressive controller
“Boost Safe” readiness safety system
Check valve integrated into nozzle to prevent unintended fluid flow
One injector and two nozzles to cover a wide range of HP levels
High Pressure 200psi Recirculation-style pump
Progressive Controller: Start Injection Boost 1-11psi. Full Injection Boost 6-39psi
LED dash light for system status and low fluid warning
20 ft. of injection tubing.
AEM Fuel Pump 50-1000 % 50-1200 Flow Chart
Walbro 400 E85 Flow Chart
Walbro 400 Gasoline Flow Chart
Message us for Specials
StreetRacerMotorSports is offline   Reply With Quote
