Old 05-18-2004, 10:28 PM   #1
sepulchral
sepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymore
Console painting
whats the simplest and cheapest way of removing old paint cleanly without scratching or sanding harshly on console dash
whats the best paint to use that wont crack or fade for console?
sepulchral is offline   Reply With Quote
Old 05-20-2004, 01:41 PM   #2
forcefedb16
forcefedb16 is an unknown quantity at this point
Send a message via AIM to forcefedb16
Try a pressure washer. Remove the console and hit it up close and this should remove most of the paint. As far as painting the plastic, the important part is prep. It needs to be lightly scuffed to give the paint something to stick to. Then use a paint specific for plastic.
forcefedb16 is offline   Reply With Quote
Old 05-20-2004, 01:45 PM   #3
element240
element240's Avatar
element240 is an unknown quantity at this point
Send a message via AIM to element240
you can find "spray paint remover" in a spray can , i used the stuff for graffiti remover, look around at the hardware stores, it works good, just let it sit awhile to let it soak in.
element240 is offline   Reply With Quote
