![]() Join Date: Sep 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 16 reviews
![]() Im trying to understand the turbo lines
Its hard to when you dont have them in your hands I went on google and looked at pics of braided lines Finally found out the oil restrictor size for ball bearing turbos I have a t25 right but will upgrade to my s15 t28 later down the road -Can i buy any turbo line kit and it will work on both turbos beside installing a .035 oil restrictor for the t28 -Does the restrictor bolt act as the banjo or do i have to get a nut for it? -what brand restictor should i go with? -cs or isis lines? Thank you for your time |
#2 | |
![]() Join Date: Jun 2010
A set of braided lines will work with both the T25 and S15 Turbo.
I have the DIF lines from FRSport, they are made with Goodridge fittings. Got the restrictor from them also. |
![]() Join Date: Nov 2010
My restrictive threads into the turbo , and provides and an fitting for my turbo line.
Presto chango!
Thank you for clearing it up for me
Pic of oil restrictor DIF 10016 Turbo Oil Restrictor -3AN to 7/16-24 (.04" Oil Hole Size) Pic of turbo lines DIF 10047 Bottom Mount Forged Turbo Coolant/Oil Lines Kit S13 SR20DET The shortest line is for the oil feed correct? The circle fitting uses a banjo to the block correct? The L shape is where you insert the restrictor and bolt to top of turbo right? |
