Old 10-08-2013, 07:54 PM   #1
FDSPIRITR
FDSPIRITR is an unknown quantity at this point
SR Downshifting oil burning smell S14 SR20DET?
Wondering what could cause this I changed all the gaskets on turbo lines. When I downshift and only when I downshift and ride down the RPMS I get this smell of burning oil. Turbo makes no weird noises spools fine doesn't smoke at all!
Anyone got any ideas only when I go into vaccum and ride down the RPMS will this smell appear. Car runs 100% no breaking up, no bad idle it runs PERFECT boost perfectly as well. Wondering if it could be a bad line or something?
FDSPIRITR is offline
Old 10-08-2013, 07:55 PM   #2
ultimateirving
ultimateirving's Avatar
You have a catch can?
Z32 with lq4 swap
ultimateirving is offline
Old 10-08-2013, 07:59 PM   #3
FDSPIRITR
Yes I do just made one a few days ago.
I replaced the turbo drain line gasket few weeks ago wondering if it didn't tighten down good enough felt like cheap bolts didn't want to snap them off....
Old 10-08-2013, 08:00 PM   #4
silviaks2nr
silviaks2nr's Avatar
that's when the motor is pulling the most vacuum so it's likely your rings or valve seals are worn.
silviaks2nr is offline
Old 10-08-2013, 08:10 PM   #5
FDSPIRITR
What's best way to test this?
Old 10-08-2013, 08:15 PM   #6
silviaks2nr
with a compression and leakdown test. The smell is also compounded by the exhaust gasses not being evacuated properly because there is no combustion to push them out like there would be when you are on the accelerator. The smell will then sort of build and sit behind the car and as you slow down enter the cabin, make sense? Some amount is "normal" if you don't have an original exhaust system.
Old 10-10-2013, 11:28 PM   #7
FDSPIRITR
just wanna update problem was found leaking oil line....... problem is fixed.
