Old 10-09-2013, 01:16 PM   #1
iLagX
Trader Rating: (40)
iLagX is an unknown quantity at this point
Feedback Score: 40 reviews
Send a message via AIM to iLagX
Thumbs up **240sx S13 s14 s15 PArt OuT *** Shipping is available
89-94 rear hatchback bumper support $30
89-94 coupe rear bumper $80 with bumper support
Doors (motor, window, switches)
89-94 complete doors shell - $100 complete 8-9 out of 10
89-94 manual windows Complete DOOR SET- $160 a set complete door 8.5 out of 10
89-98 driver/passenger side mirror - $40 each power or manual
LE power door panels clean $150 9.5 out of 10.
Interior (*Seats, interior panels, arm rest, center piece, dashboard, etc**)
dohc cluster $100
95-96 white face cluster SE $100 ~2xx,xxx
ULTRA RARE 89-94 NISMO 140MPH CLUSTER $350 ~165k
89-98 Clean black or blue cluster trim $40
1989-1994 or 1995-1998 complete center console with arm rest $80
Working A/C CLIMATE CONTROL - 1989-1998 $40
89-94 OEM coupe quarter window glass - $60 each obo
89-98 Glove box $40
stock s13 seat with rail cloth or brown leather $30 passengerside only.
Nissan 240sx 1995 - 1998 Zenki, Kouki S14a
clean flawless condition steering wheel $70 no air bag
Airbag passengerside - $40
no cracks 1/4 quarter panel glass- $80
Tail Lights
JDM kouki tail lights $350 95-98
89-94 3 piece hatch tail light or coupe $60
95-98 3 piece smoked zenki tail lights $60
89-94 d-max LED smoked red with oem 180sx center garish - $550 Plug and play.
Cooling
stock s14 fan shroud $60
Brake System
- 300zx to 350z brake caliper bracket $120 NEW
- BMC 1 1/16 brake master cylinder for s13 s14 s15 z32 $120 NEW
- 89-98 S13 s14 Stock Front brake caliper with brake bracket $60 a pair
-300zx big brake upgrade bbk $350 obo with rotors
Exhaust System
1995-1998 CAT Converter aka Down pipe $100
95-98 Catback exhaust system $100 with aftermarket muffer Serbling
89-94 Rs-R GT-2 Full catback $350
Megan Type II exhaust s14 $320 perfect for n/a or turbo low key exhaust
Megan collars $60 obo ** NEW*
New derlin Motor Mounts KA/SR Direct bolt on - $80
89-90; 91-94 exhaust manifold - $60
89-98 starter / alternater $60
89-90 or 91-94 S13 down pipe- $50
MAF (mass air flow sensor) SOHC 89-90 $60 or SR,
- Suspension
-oem stock s13 or s14 suspension set. $120
- new Megan tension rod $80 s14
- Drivetrain
S14 Front subrame $120 Straight NO BENTS OR DAMAGED. 95-98
S13 REAR subframe clean $80 BARE or $250 complete with diff;
S14 $350 Complete ; Subframe Z32 $80
95-98 $120 open diff aka 3rd member, pumkin
89-98 s13, s14 6 bolt axle $50 each or $80 a set.
89-94 s13 rear control arm $50 each s14 $80 Each
s13 or s14 traction arm, toe arm, camber arms - $20 each or $30 a pair.
s13 rear 4 lug hub $40 or $60 for both. GOOD BEARING
S14 front control arms $220 or $120 each OEM
Full front end conversion for s15 $2200
Vis carbon fiber hood -450
oem spec r bumper -550
oem spec black housing headlights -650
brackets
hood hinges
conversion fenders -350
Semi Complete kouki conversion $1200 for the whole set or part out
Seibon carbon fiber vented hood with flush mount hood pin lock (key included) $450
JDM bumper support $150
oem bumper retainer $100
Kouki fenders white $500
kouki headlights $500 x2 passenger x1 driverside
kouki corners $120
Jdm kouki grill $150
PARTING OUT S13/S14 NEED PARTS PM ME!
iLagX is offline   Reply With Quote
Old 10-09-2013, 08:05 PM   #2
sr20detS15
sr20detS15's Avatar
sr20detS15 is an unknown quantity at this point
Send a message via MSN to sr20detS15
pix of the s15 bumper
sr20detS15 is offline   Reply With Quote
Old 10-12-2013, 04:42 PM   #3
iLagX
Trader Rating: (40)
leave a message or pm for pictures.
Old 10-13-2013, 09:45 AM   #4
Clicky
Clicky is an unknown quantity at this point
200 for kouki fenders!!!
Clicky is offline   Reply With Quote
Old 10-13-2013, 03:50 PM   #5
lake_release
lake_release is an unknown quantity at this point
Hey I really need that passenger airbag side for the s14 Kouki ...do u have a pic?i stay in the 562 area code
lake_release is offline   Reply With Quote
Old 10-13-2013, 04:25 PM   #6
Clicky
Seriously tho. Do you have an s14 non abs drive shaft
Old 10-14-2013, 02:16 PM   #7
mysniswhack
mysniswhack is an unknown quantity at this point
Looking to buy just the driverside kouki fender. Im in LA too 6196721359
mysniswhack is offline   Reply With Quote
Old 10-14-2013, 04:21 PM   #8
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
Pix of the S13 coupe tails?
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 10-14-2013, 05:01 PM   #9
Dutchmalmiss
Dutchmalmiss's Avatar
Dutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfection
Send a message via AIM to Dutchmalmiss
$10 for gauge cluster glass? LMK.
Pignose, biaaatch.
Dutchmalmiss is offline   Reply With Quote
Old 10-15-2013, 10:29 AM   #10
OutlawLui
OutlawLui's Avatar
OutlawLui is a well-known jackass
Do u have s13 fuel level sensor?
OutlawLui is offline   Reply With Quote
Old 10-16-2013, 12:40 AM   #11
iLagX
Trader Rating: (40)
you guys got pmed!
if you not then i dont have it or like your offers.
Old 10-16-2013, 03:36 PM   #12
xanu8isx
xanu8isx is an unknown quantity at this point
S15 conversion fenders!!!!! Pm me back
xanu8isx is offline   Reply With Quote
Old 10-17-2013, 01:54 AM   #13
Adrift
Adrift is an unknown quantity at this point
Fujita intake still for sale?
Adrift is offline   Reply With Quote
Old 10-21-2013, 10:07 AM   #14
75bluemage
75bluemage is an unknown quantity at this point
How much for s13 dash and can I see some pics
Sent from my iPhone using Tapatalk - now Free
75bluemage is offline   Reply With Quote
Old 10-21-2013, 10:51 AM   #15
monkichi57
monkichi57's Avatar
monkichi57 is an unknown quantity at this point
Still got the rear LCAs and spindles for S14? If so, how much shipped to 96789? LMK
monkichi57 is offline   Reply With Quote
Old 10-21-2013, 05:54 PM   #16
sliding_josh
sliding_josh's Avatar
sliding_josh is an unknown quantity at this point
PM me pics of the D-MAX tails please.
sliding_josh is offline   Reply With Quote
Old 10-22-2013, 09:24 PM   #17
Rb30koukiS14
Trader Rating: (-1)
Rb30koukiS14 is an unknown quantity at this point
Feedback Score: -1 reviews
Still got them kouki tail lights?
Rb30koukiS14 is offline   Reply With Quote
Old 10-27-2013, 08:37 PM   #18
SR20PWRALTY
SR20PWRALTY is an unknown quantity at this point
PMed you about bcm
SR20PWRALTY is offline   Reply With Quote
Old 10-28-2013, 01:02 AM   #19
heychris
heychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura about
Do you have an s13 KADE ecu (manual tranny)? If so how much?
Ch
Sent using XT912 M
heychris is offline   Reply With Quote
Old 10-29-2013, 02:19 AM   #20
ag240sx
ag240sx's Avatar
ag240sx is an unknown quantity at this point
pix of vented hood?
ag240sx is offline   Reply With Quote
Old 10-29-2013, 10:29 PM   #21
75bluemage
Interested in big brake kit text me 9513553141
Old 10-29-2013, 10:52 PM   #22
driftage240
driftage240's Avatar
driftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfection
Send a message via AIM to driftage240
Pics of the rs-2 s13 cat back?
Misty blu is coming 4 you!
driftage240 is offline   Reply With Quote
Old 10-30-2013, 03:41 AM   #23
Jizzyjozay
Jizzyjozay's Avatar
Jizzyjozay is an unknown quantity at this point
Is it the stock alternator
Jizzyjozay is offline   Reply With Quote
Old 10-30-2013, 05:54 AM   #24
Slow96240sx
Slow96240sx is an unknown quantity at this point
S14 radio bezel
How much if you have it
Slow96240sx is offline   Reply With Quote
Old 10-30-2013, 12:08 PM   #25
DUBSTEP
DUBSTEP's Avatar
DUBSTEP is an unknown quantity at this point
Do u have black power door panels?
DUBSTEP is offline   Reply With Quote
Old 10-30-2013, 01:54 PM   #26
zenkiset
zenkiset is an unknown quantity at this point
would you sell just the stock s13 front springs?
A welded is like the car equivalent to a blowjob.
zenkiset is offline   Reply With Quote
Old 10-30-2013, 02:58 PM   #27
iLagX
Trader Rating: (40)
Old 10-30-2013, 10:01 PM   #28
campbells13
campbells13's Avatar
campbells13 is an unknown quantity at this point
Have a s13 driver window motor ? If so lmk 7144040432
campbells13 is offline   Reply With Quote
Old 11-12-2013, 09:21 PM   #29
iLagX
Trader Rating: (40)
Clean brown set door panels. 8 out of 10.
$80
Old 11-13-2013, 01:45 AM   #30
Looneybry
Looneybry's Avatar
Looneybry is an unknown quantity at this point
Any window switches
Looneybry is offline   Reply With Quote
