Old 10-22-2013, 03:03 PM   #1
charlie@justdrift
charlie@justdrift's Avatar
charlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond repute
Send a message via AIM to charlie@justdrift Send a message via Yahoo to charlie@justdrift
Fs: S14 sr20det motor set - details inside
$5500 for my entire setup - engine runs, you can test it before pulling it out. Socal 818 area - can be pulled out at Design Craft in OC.
S14 SR20DET
Arias Piston 86.5mm
Eagle Rods with ARP Rod Bolts
ACL Race Bearings for Main Rod and Thrush
ARP Head Studs
ARP Main Studs
Crank micro Polish
Cosworth 87mm X 1.1mm
Tomei Pon Cams
BC titanium Retainers and Springs
Assembly was Balanced
Real Greddy Oil Pan
Real Greddy Intake manifold
Custom AN fitting for Oil feed and drain and Waterline
Garrett Turbo GT3071R
AEM EMS
550cc apexi injectors
Z32 Tranny - Mazworks conversion
Maz work drive shaft
Maz work shifter
AEM EMS2
AEM Tru boost controller
Tuned at 18psi 400hp 110 leaded
it's already tuned and running very good! never had an issue, just change oil, tires and put gas. no over heating nothing!
have new motor coming soon... will not part out. please don't ask for part out. if you want, buy the motor set and part it out yourself. no low balling either =)
charlie@justdrift is offline   Reply With Quote
Old 11-18-2013, 04:13 PM   #2
Driftzenki
Driftzenki is an unknown quantity at this point
would u part out the greddy oil pan?
Driftzenki is offline   Reply With Quote
Old 11-18-2013, 05:38 PM   #3
steveoen
steveoen is an unknown quantity at this point
so reading is hard for you then?
steveoen is offline   Reply With Quote
Old 11-18-2013, 06:57 PM   #4
Driftzenki
Lol..i simple no would suffice..it has been a month since u posted..maybe u changed ur mind
