Old 10-25-2013, 01:25 AM   #1
Ikera
Ikera's Avatar
Ikera is an unknown quantity at this point
KA Alternator Help
my volts are low,
ignition off ~11.0V
idling ~11.0V
@2000RPM ~12.0V
so the alternator is generating some electricity, just not enough to keep the battery charged
the FSM alternator trouble shooting didn't apply to me
Ignition of - Batt light on (normal)
idling - Batt light off (normal)
@1500RPM - Batt light off (normal)
checked the fuses under the hood, everything is ok
the voltage reading under the hood, in the truck and at ECU is all the same
the engine is KA24ET, there was no water leaking on the alternator, but I do have a hard hitting 12" Sub and an AMP in the hatch
HELP!!
Ikera is offline   Reply With Quote
Old 10-25-2013, 01:49 AM   #2
rwtf
rwtf's Avatar
rwtf is an unknown quantity at this point
um....bad alt? volt regulator? lol pretty damn obvious
rwtf is offline   Reply With Quote
Old 10-25-2013, 02:48 AM   #3
Ikera
Ikera's Avatar
why doesn't the batt light come on in any of the trouble shooting scenarios?
alternators aren't cheap wouldn't want to replace if I don't have to.
If there is nothing else to try with an alt in the car I'll take it out and take it apart then
and check the voltage regulator
Old 10-25-2013, 02:57 AM   #4
rwtf
rwtf's Avatar
you know advance can test them...for free right...? facepalm.
Old 10-25-2013, 10:19 AM   #5
Ikera
Ikera's Avatar
nope, and I didn't know what "advance" is until I googled it. The nearest one is across the border, but I will try to find out if anybody else does this type of service around here
Old 10-25-2013, 11:06 AM   #6
ultimateirving
ultimateirving's Avatar
What does can have for automotive parts stores? Auto zone oreilly can both test em here stateside
Z32 with lq4 swap
Old 10-25-2013, 11:12 AM   #7
drumer_boy456
drumer_boy456's Avatar
drumer_boy456 is an unknown quantity at this point
drumer_boy456 is offline   Reply With Quote
Old 10-25-2013, 11:27 AM   #8
blkvrtswp
blkvrtswp's Avatar
blkvrtswp is an unknown quantity at this point
Lots of stores are no longer testing alternators due to the newer complex electronic ones giving constant 'bad' indications. Great for sales until the customer catches on. I actually had a hard time finding anyone other than Autozone here in NY.
You can find rebuilt alts on ebay - look for good feedback, last one I bought was around $75 shipped and it was excellent.
blkvrtswp is offline   Reply With Quote
Old 10-25-2013, 11:32 AM   #9
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
How old is the battery?
What's your battery's resting voltage?
What is the battery's voltage reading when running? When you rev it does the voltage go up?
If the battery is below 12 volts with the car off, the battery is probably on it's way out.
If you're running anything below 12V when the car is running the alternator is not returning enough voltage to your battery and is actually shortening the life of your battery.
Old 10-25-2013, 11:59 AM   #10
Ikera
Ikera's Avatar
Lordco and NAPA
resting about ~11.0V, idling same ~11.0V if I rev it up to 2000PRM the voltage does go up to ~12.0V
I'll try swapping in a battery from my other car
Old 10-25-2013, 01:10 PM   #11
shogunstyles15
shogunstyles15 is an unknown quantity at this point
Did you have any luck finding an auto parts store to test your alt in your area? You can go around in circles trying to trouble shoot it but the EASY way is to take the part out and take it to the store. Other than that you already have all the info you need. Its operating below acceptable levels so its time for a replacement. GL with your project.
shogunstyles15 is offline   Reply With Quote
alternator, battery issues, battery light, sohc
