![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
SHOP CLEANOUT! aftermarket/OE, TONS of S13, some S14, CHEAP!!!
Well, it's time to clean-out the shelves here at the shop! I have finally gathered all the random parts sitting around that I think someone else might need. I will ship, unless stated otherwise. I will make package deals and will be much more willing to lower the price for pick-up/cash transactions. Remember, shipping is a PITA and my time is valuable...
Parts are located at my work in Northridge, 91324... I will be adding more parts as I dig them up, check back for updates! Work RS-Beta centercaps These are 3 ORIGINAL Work RS-Beta centercaps. Two of the caps are in pretty good shape, just some small scratches in he clearcoat. The thirdcap has the clearcoat peeling and would need restoration to look good. $20/ea for the clean pair $10 for the damaged one ![]() ![]() ![]() S13 subframe bushing inserts This is a BNIB set of S13 subframe bushing inserts, made by energy suspension. These slide into the hollow areas of your stock bushings to stiffen them up a little. EVERYTHING is included, bag is unopened. $10 ![]() S14 passenger's side urethane steering rack bushing This is a passenger's side steering rack bushing for an S14 chasis. It is made by energy suspension and has never been used. $5 ![]() KA M/T starter bolts This is a mis-matched pair of bolts for the KA w/manual transmission starter bolts. Both bolts are metric grade 8.8 and both come with lockwashers. The heads of both bolts are also the same size so you can use the same socket. $10 shipped ![]() S13/14 clutch and brake pedal pins These are the pins for either the clutch or the brake pedals on an S13 or S14. These two are actually from the brake pedal, but will work on either one perfectly. I have 5 of these available! ONE is an actual clutch pin, not that it matters... $5/ea ![]() Sidemount Seat Brackets This is a pair of sidemount seat brackets. I have no idea what seat these are for. The seat must be much narrower in the rear than the front. $20 ![]() Pair of Spacers for TEIN tension rods This is a pair of spacers for TEIN tension rods. If you lose these you're screwed so I figure someone could use them. $20 ![]() S13 RR lower control arm This is a good condition S13 right rear lower control arm. The boot for the balljoint is there, but no chunks are missing and it seals pretty good once installed. The balljoint is also in great shape. Nice and tight, moves freely, grease looks clean and fresh. The bushings are also still good, not torn. The plastic cover is still attached to the bottom of the arm as well, 100% original. $10 ![]() S13 stock hubs w/good bearings These are stock 4-lug S13 hubs with good bearings. I have one front and one rear. All studs are included and in good shape. $10/ea ![]() S13 steering shaft u-joint This is the u-joint for where the steering shaft connects to the rack on an S13. It is in SUPER good shape. NICE and SMOOTH, NO PLAY. $15 ![]() Redtop SR coolant sensor subharness This is a coolant sensor subharness for an S13 SR20DET. The harness is in good shape, no issues. $15 ![]() SR starter pigtail This is the CORRECT FACTORY pigtail for the starter on any SR. The connectors are different from the KA ones and you should be using your KA lower harness with your SR swap. If you're anal, like me, and want the CORRECT connector here it is... $5 ![]() Pigtails/connectors for SR wiring I have two complete sets of connectors for wiring an SR harness for a 240sx chasis. The connectors are all in good shape, no issues. This would be perfect for someone who doesn't want to hack-up their KA harness or if you don't have the stock engine harness. For the underdash plug I DO NOT cut and solder the wires. I simply re-pin the wiring into the new connector. For a dualcam swap you just swap the pins directly across to the same position in the new connector. For the SR wiring you'll have to do a little more research on how to pin them. FR sport has a GREAT write-up. Two of the underdash plugs are already de-pinned and one of the others isn't actually for the underdash harness so the wire colors won't match. I also have the dash harness connector separately for those of you doing a DOHC swap. $15/set (specify if your chasis was originally SOHC or DOHC...) ![]() S14 KA IACV This is a good working S14 IACV valve. It's in good shape no damage. I'm not sure if it would work on an S13 KA, you would need to check the part numbers to be sure. $20 ![]() S14 KA EGR solenoid This is a good condition used EGR solenoid for an S14 KA24DE. New these are about $100 from the dealer... $20 ![]() KADE or SR oil caps This is a pair of oil filler caps for an SR or KADE. These will NOT fit a singlecam and I don't know about CA. Both caps are in good condition. $5/ea all black cap on left SOLD!!! ![]() KA dipsticks These are both KA dipsticks, one singlecam one dualcam. Both are in good shape, no damage. The dualcam is on top in the pic and the singlecam is the longer one on the bottom. $5/ea ![]() S13 SOHC injectors These are S13 SOHC KA injectors, I have 7 available. ALL injectors have been tested electrically, terminals cleaned, and are known to be good. NO seals are included. Nissan injectors LOVE to take a shit, everyone should have a spare. $10/ea ![]() KAE NGK wires for MSD style coil This is a full set of NGK spark plug wires for a SOHC KA. The coil wire has been modified for and MSD style coil. $20 ![]() KAE coolant guage sender This is the coolant sensor for the guage for a SOHC KA. This one is almost new, replaced VERY recently. $5 ![]() KAE distributor This is a good condition distributor from a SOHC KA. It is an 100% good working order and was removed from a running/driving engine. Cap and rotor are also included. $20 ![]() S13 KAE alternator This is an alternator from an S13 SOHC KA. It can be used on a dualcam as well, you've just gotta swap the pulley. It is in 100% good working condition and was removed from a running/driving car. $25 ![]() KA starter This is a starter for any KA. It is in 100% good working order and was removed from a running/driving car. $25 ![]() S13 driver's and passenger's side dash vents These are a pair of S13 dash vents, passenger's side and driver's. I do not have the center vent. The vents are in pretty good shape, 100% functional. $5/ea ![]() S13 fastback headliner This is a headliner from an S13 fastback. The headliner is in pertty good shape, no rips or burns just needs cleaning. $15 ![]() S13 passenger's side window switch/handle This is a good condition passenger's side inner door handle with the power window switch for the passenger's side of an S13. The handle is in very good shape, just the writing is worn off like normal. $15 ![]() S13 inner door handle screw covers This is a pair of the screw covers that go in the bottom of the inner door handles on an S13. These are usually missing and are hard to find. Will post better pic, I didn't realize how out of focus that was... $10 shipped ![]() S13 manual window crank These are window crank assemblies for an S13. They are faded as usual, but compared to a lot of them is in pretty good shape. The clip and the plastic washer are included as well. $5/ea ![]() S13 power window amp This is a good condition power window amp from an S13. It came off the passenger's side, not sure if it would work on the driver's which is why I took a pic of the label. These things are about $100 from the dealer and frequently go bad. $35 ![]() S13 pop-up headlight subharnesses These are 3 S13 pop-up headlight subharnesses. These are often damaged or missing. Most people don't know that Silvia headlights SHOULD come with a subharness of their own that plugs into this harness for the headlights. $10/ea one pair SOLD! ![]() S13 rear hood seal This is the seal that goes along the back of the engine bay and seals the hood for an s13. The seal is in good shape and all clips are included. $5 ![]() S13 corner lights These are good condition S13 corner lamps. The rears are a matched set, left and right, and come with the sockets. The fronts are BOTH for the right side and DO NOT come with the sockets. The socket in the pic has been used on another car. You can use them on the left side as well, the writing on the lens would just be upside-down. $5/ea ![]() Stock fastback rear tail light panels These are the stock USDM tail light panels for an S13 fastback. Both panels are straight, no bends or dents. $10/ea ![]() S13 fastback rear bumper This is a stock rear bumper from an S13 fastback. The bumper is in pretty good shape, just a small scuff on one corner and some paint damage on the other. $20 ![]() ![]() ![]() ![]() S13 front swaybar link This is a front swaybar link for an S13 chasis. It should work on an S14 as well. This one is in good condition, moves free, nice and tight. $5 ![]() RANDOM CRAP... I also have a whole shitload of small random stuff as well. I've got 3 boxes full of wiring, relays, switches, and other misc electrical shit. I've got 2 parts shells, one coupe and one hatch. If you need a random small part that's not listed HIT ME UP! I probably have it... Random wiring: ![]() Misc. Electrical: ![]() The infamous "240 bucket": ![]() Coupe parts shell: The HUD windshield is spoken for on this one, sorry. Was a full power option car, pretty well parted out though... ![]() Fastback parts shell: The windshield and tires are spoken for on this one, sorry. This car was manual everything, no power, and is also pretty well parted... ![]() Last edited by racepar1; 11-09-2013 at 11:09 PM.. |
