Old 11-06-2013, 06:05 PM   #1
Jersthecool
Jersthecool is an unknown quantity at this point
Car won't start randomly
So my car started leaking coolant so I pulled it in the garage today to take a look and started looking at the back of the motor and unplugged the coilpack harness to see back there better. There's a bunch of oil so I couldn't really see any coolant so I thought I'd start it up and check for leaks while it's running. So I reconnect the coilpack harness and all it does is crank for some reason. It's getting fuel you can smell it and the plugs were all wet with fuel and checked spark of all the plugs and coilpacks and they're all giving of a spark. Don't know randomly why it would have a problem starting when it started perfectly fine right before I moved it into the garage then boom nothing. Any ideas?
EDIT: It's on an SR swapped 240 btw
Jersthecool is offline   Reply With Quote
