Old 11-07-2013, 07:20 PM   #1
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Porsche Brembo calipers, CHEAP!!!
This is a PAIR of Porsche calipers, made by Brembo. These are 928 S4 rear calipers, about the same dimensions as a 300zx 26mm caliper. The original rotor diameter was 299mm (11.77") and 24mm thick (.94"). I would use a 12" diameter, 1" thick rotor with these personally. The calipers are in mechanically good shape, no leaks. The finish is a little rough and they could definitely use a re-paint. You will need custom brackets and rotors to use these. I do not have the brackets or rotors. These would make a GREAT front setup on a lower powered/lightweight car (miata, ae86, 240, etc...) and probably would not require a master upgrade due to the smaller pistons. They would also make a GREAT rear setup for a higher powered car. Pair these with a set of Porsche Brembo "big red" or the corresponding 928 S4 front calipers and you'll be able to stop the earth's rotation at will!
SOLD!
