Old 11-11-2013, 11:07 AM   #1
teh smithers
teh smithers's Avatar
teh smithers is an unknown quantity at this point
s14 Steering Wheel Not Auto-Centering: Help!
I fiddled with a few things on my S14, and prior to my fiddlings, the steering system auto-centered as it should. Now, when I steer into a corner, the wheel doesn't re-center AT ALL. Literally, I can make it through a corner without touching the wheel. Granted, this is highly entertaining, but also highly annoying. I'd like to fix it.
My steering wheel is a S15 OEM item. It's been on the car since I bought it, and never behaved this way, until now.
My list of fiddles:
- New clock spring installed to fix my horn. My turn signals don't cancel anymore, so I know I installed it incorrectly. (At least the horn works again.)
- New front coilovers installed (Fortune Auto 500's). I've read of people installing new struts, and afterwards experiencing a problem similar to mine. I've installed coilovers before, though, and didn't encounter this steering problem.
- Mild fiddling with toe angle and caster angle. Nothing drastic.
My ideas on what's causing my issue:
- Clock spring installed incorrectly?
- Coilovers installed incorrectly? (Doubtful)
- Caster or toe way out of alignment? (Which I also doubt, because I've never encountered this problem before, no matter how atrocious my alignment was.)
Helpful folks are highly encouraged to reply. Thank you
teh smithers is offline   Reply With Quote
