Old 05-27-2004, 02:49 PM   #1
Johny5
Johny5's Avatar
height adjustable camber plate questions?
i've never heard of anyone having these on here so i figured i'd ask. i just picked up some project mu front camber plates for s14 and am putting them on with agx/sportlines (yes they have the spacers). it has a coilover style heigh adjustment with the same collar to lock the piece that holds the top of the shock thats threaded into the adjustment plate. how much should i screw that up (i.e. lower the car, help my shock stroke) before its unsafe. i know 5 threads is probably unsafe for the type of driving this thing sees at the track. should i do, what, like 10 or so threads? any help is help, and pics coming up tonight. thanks!
www.stewartleask.com
Johny5 is offline   Reply With Quote
Old 05-28-2004, 06:43 AM   #2
Johny5
Johny5's Avatar
this might help...
Old 05-28-2004, 01:02 PM   #3
Johny5
Johny5's Avatar
does no one have these or does no one know? i put the two spacers on before i put the mount on and i do not have it maxed out in drop. yet when i turn my wheel a full turn/turn and a half, i hear a loud pop and when i put it straight again it wants to very badly turn to the direction i was just turning. so say i do a left hand u-turn, after i straighten out the car wants to vear left. do i need to raise the height? is the mount hitting the top of the shock holder? i really really need help before something fcks up please.
Old 05-28-2004, 01:11 PM   #4
hurleyboi514
hurleyboi514 is a well-known jackass
Send a message via AIM to hurleyboi514
mine does that when i dial in too much camber.
HighTach Motorsports
hurleyboi514 is offline   Reply With Quote
Old 05-28-2004, 01:13 PM   #5
Johny5
Johny5's Avatar
shit! so i have to actually get rid of some of my camber? ghey.
Old 05-28-2004, 01:21 PM   #6
DuffMan
DuffMan's Avatar
DuffMan is an unknown quantity at this point
Send a message via Yahoo to DuffMan
It sounds like the upper spring seat is getting stuck, and when you turn, the coil is twisting and causing it to want to pull back. Is there a way to get that upper spring seat to be mounted lower on the shaft? I've never taken apart the stock upper mount, so I'm not really sure.
DuffMan is offline   Reply With Quote
Old 05-28-2004, 01:29 PM   #7
Johny5
Johny5's Avatar
no, there's no way to move the upper spring seat itself. there is an alternative however, and i can raise the actual mount part with the 3 studs in it, i can spin it and raise/lower where the shock rod meets the heim joint +-1" should i just try lowering the heim joint so that the spring seat is further from the mount part with the studs in it?
Old 05-28-2004, 04:31 PM   #8
DuffMan
DuffMan's Avatar
I guess you have to
Old 05-28-2004, 07:44 PM   #9
Johny5
Johny5's Avatar
ahhhh chit, i liked having it an extra inch lower too. man, whats the point of paying the extra $150 for these things if i cannot use the drop, and whats the point of plates if i cannot max the camber? this blows.
Old 05-28-2004, 08:08 PM   #10
knightrider
knightrider's Avatar
knightrider is an unknown quantity at this point
well, if you had coilovers with small diameter springs, you could use the extra inch but since you have normal springs, your sol, plus the camber plates themselves will lower the car around an inch because the stock upper mounts are so tall, my cuscos lowered my car about an inch, and they arent adjustable like yours.
Drift_ Into A Mountain
Jim Wolf Technology
Stock CA18DET-SR T25-greddy FMIC-JWT SR Lightened FLywheel-300zxTTclutch-SR20DET JWT tuned Ecu
knightrider is offline   Reply With Quote
Old 05-28-2004, 08:23 PM   #11
Johny5
Johny5's Avatar
or if i just went gc's? oh well, i'm plannin on the whole coilover route in a bit, for now i guess i just have to appreciate the stiffness of the mount.
Old 06-27-2004, 12:53 AM   #12
CrispMofo
CrispMofo's Avatar
CrispMofo is an unknown quantity at this point
I had camber plates on my strut/spring combo and heard pops too except the small camber adjusting bolts started popping off in the air.
CrispMofo is offline   Reply With Quote
