![]() Join Date: Sep 2006
![]() Feedback Score: 23 reviews
SKYLINE TRUCK (hakosuka sunny) for sale!!
so i was checking prices of hakosuka items (a few people have contacted me about sourcing them hakosuka parts so that they could try their hand(s) at a skyline 620) when i come across this....
?????????????????????????????? - ????! thats right, the infamous skyline truck is for sale! ![]() ![]() ![]() description says its 1200cc and here is a rough translation of more description: It becomes an exhibition of Sanitora of modified large number. Thank you for your consideration in the more car enthusiast there is a readiness and knowledge of its own way it will be special vehicle Yes to remodel considerably. Might dwell small scratch for the full restoration car that has been subjected to rust with tension inside and outside the iron plate was excised, but is a beautiful vehicle place that had rust in the white body once. I think it possible to have you aboard long if you can to take care for below has also been thoroughly restored. I think inspection is Mantan state currently almost but whether depending on the region because it is the vehicle width certified already in late-type base of emission regulations, but I think inspection also whether through in some specifications changes. It may not be of high Fra becomes that failure point does not turn in a slump occasionally turn signal current. There is a possibility of relay failure. Also It's not a bug, but the pedal force and some subtleties are required for the master backless. In addition, we modify it so that another image of steering, wheel, speaker. I will remove the (応談possible) frame number. The meter will move a little tone for maintenance. Well, tone Wakayama Prefecture, southern basically Because it is changing spear set also gums window around changes to the new enhanced dynamo and set exchange such as seals of the engine, brake pipes, fuel piping, etc. other hoses to restore time We went Osaka and Kyoto, Nara and even more, but the running of the highway had been stable. Although it is about dealings but direct delivery, it is possible both land transportation. Thank you to check the current car as much as possible so that we no claim no return. I will ask questions to convincing If you can not if.Thank you it will be a special vehicle. In addition we will deposit the 50,000 yen deposit to complete the name change because it is a vehicle with a vehicle inspection. Please acknowledge forfeiture of deposit, because it will be forced cancellation of the vehicle when you can not name change within three weeks after it has dealings. Will be remodeling point below. Body exterior exterior is Hakosuka face as you can see. I do the processing in various parts were purchased in the new kit. Color it becomes silver large metal eyes Gun Metal a little closer with the depth also commonly than in silver color scheme at synchro silver metallic color of the S2000 pure color. Such as the hood and fenders has become a gunmetal original color to accent. 09RACING Hakotorakitto + various parts processing Hakosuka GTR genuine mirror panel ll Hakosuka for rear plate71 for rear wing processing one-off slit GPZ900R for aluminum billet fuel cap fuel pipe stainless one-off Moro software bonnet pin to put up (Furoagomu bed Hippo over liner coarse finish ) rear opening stainless steel chain four-lamp HID 8000K number light LED processing smoked tail processing various parts smoothing full restoration under guard all paint all paint interior Yes painted with details finish the repaired Hippo over liner of rust after you Dongara interior, dashboard I am finished in black with interior door only amount based on those without a tear or crack, etc.. The keyless, too. Auto Meter (real) Sports Comp Otogeji water temperature, oil temperature, oil pressure gauge carbon block processing mounting missile switch breaks Godfather 6 stations air horn buttonHakosuka genuine console box processing installation DVD deck Mitsubishi Electric separation type ETC keyless entry Datsun replica bucket seat left and right one-off aluminum island Itamatto Fire Blitz room lamp LED processing (horizontal under the seat) dry battery relocation wiper motor relocation processing Hippo liner over Hoso-chi finishdash, door panels black paint various parts door weatherstrip new engine room is usually in the first and each part smoothing engine room what you get is a special process to hide as much as possible. I am finished to look very simple because it is. It is the part that was produced by attention to a single bolt has been applied work very time-consuming to understand for anyone who is a part, such as do not know if you do not explain, but it can be seen. Various parts unnecessary hole smoothing engine harness production redrawing harness other one-off master backless genuine Nissan other car diversion master back again pull brake line one-off re-drawn one-off fuel piping redrawing heater hose one-off redrawing speedometer cable one-off battery relocation wiper motor relocation various parts stainless bolt used for each part one-off aluminum bolt ring use full restoration House of color 08 tangerine engine, around the foot, drive system, other engine body as bike apparently was something thing only replaced the seals on our side, but it was on the original good There is also a power in such sharp response. I think what you have installed and those which we have confirmed only I indicate, but tuning more as though it was so did not confirm by opening up the contents.One-off full Stainless muffler Octopus (Thermo Vantage specification) MDI ignition coilMDI plug cord Kameari strengthening alternator Kameari turnbuckle dynamo staylightweight flywheel strengthening clutch aluminum three-layer radiator aluminum reserve tank silicon radiator hose silicon heater hose Solex 44 (sandblasting after OH) air funnel(head oval port-based) port processing engine tappet cover processing aluminum part buffing various parts stainless bolt use block painting suspension front shock-absorberRiarifu reclassified down block def 2WAY LSD other Godfather air horn is remodeling point, but there is a possibility that it is forgotten it still . I will present car super If you had forgot to write because it is felt to say the part that is not tampered with anything, especially with only glass and a seat belt. In addition, such as extra parts when production is also a freebie degree, but we will, if necessary. Check the current car as much as possible, you inquiry please the person who can have low interest year old car, because it is a funny car as described above. Thank you for your attention. and guess how much its going for? like think of a number in your head.... . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ONLY 2 million JPY! the USD is doing really good in japan right now, approx 98jpy to 1usd, so its just a little over $20k!
formerly known as "hotboiblaze" ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
![]() Join Date: Oct 2004
![]() ![]() ![]() Feedback Score: 11 reviews
Would be a great little daily hauler. Nice find Dale
Have you contacted 09 racing about the Hakotora Kit? They finally updated the website with a price http://09racingshop.cart.fc2.com/ |
#3 | |
Back when I lived in Va I seen one of these little Datsun trucks at a place I bought 240 parts I wanted it pretty badly but the guy wouldn't part with it even though it was just sitting in the weeds. I always thought it could look bad ass........
Now I know just how bad ass it could have >.< |
#8 |
![]() Join Date: Jul 2012
Paying somebody 20k plus shipping for that thing would be as dumb as paying somebody 20k for a JDM s13. You can find a bone stock sunny truck in Japan for $1000 or less. You can order everything else you need to convert it, as well as having everything shipped for a third of their asking price. For 20k it better come with a built rb26 and two spare rb26's in the bed of it.
#9 | |
sunnys are also in south america, and maybe mexico even (idk.) it would be cheaper to source one from south america than shipping it from japan. i would think
#12 |
no. i thought the same thing and i was wondering if found the actual car or a stupid 1/XX replica
