Old 05-30-2004, 05:27 PM   #1
LowBattery
LowBattery's Avatar
LowBattery is an unknown quantity at this point
Spark Plug Question
I just changed my spark plugs today, but when I took out the second plug wire, the tip was covered with some orange stuff, and the body of the plug looked like it was covered in rust. The third wire looked the same as third, but the plug wasn't rusted. Does this mean anything serious? or did some water just get in there to cause the rusting? The tip of the plugs looked fine, and I haven't had any noticeable engine problems, so I'm not sure if there's anything wrong. I've also attached some pictures of the plug and wire, if that will help. Thanks in advance.
LowBattery is offline   Reply With Quote
Old 05-30-2004, 11:03 PM   #2
DORIMON
DORIMON's Avatar
DORIMON is an unknown quantity at this point
Looks like a little moisture was trapped in there for awhile causing rust. Just clean everything well and you should be okay assuming you didn't have any problems before.
DORIMON is offline   Reply With Quote
Old 05-31-2004, 12:34 AM   #3
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
I wouldnt even worry about that. Its not rust from combustion chamber.
sr240mike is offline   Reply With Quote
Old 05-31-2004, 10:23 PM   #4
LowBattery
LowBattery's Avatar
Cool. That's very comforting to know, Thanks.
