Old 12-16-2013, 04:42 PM   #1
mx4evr
mx4evr's Avatar
mx4evr is an unknown quantity at this point
Axle-Nut help
Hey,
I'm currently freshening up my rear subframe. When I took the subfame apart, the car already had a z32 brake conversion. Problem was they hadn't included the e-brake conversion. Now I do have the parts for the e-brake but I can't get the axle nut off the axle.
Right now, I have the rear uprights still connected to the axle, but off of the car. Does anyone know of a way that I can wrestle the axle nut off the axle without having to reconnect all of the suspension arms to the car and drop the car's weight to hold it still?
Thanks,
Nick
mx4evr is offline   Reply With Quote
Old 12-16-2013, 04:48 PM   #2
az_240
az_240's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
If the brakes are still hooked up just have someone hold them down while you loosen it.
If not, try wedging a large prybar between the wheel studs and have someone hold it in place while you loosen the nut.
Old 12-16-2013, 08:16 PM   #3
BoredEE
BoredEE is an unknown quantity at this point
Maybe a smartass answer but the best one possible:
Air compressor and an impact gun
BoredEE is offline   Reply With Quote
Old 12-17-2013, 07:34 AM   #4
Frank_Jaeger
Frank_Jaeger is an unknown quantity at this point
You need at least a 12ft long breaker bar and a trampoline. Good luck!
Or maybe try using a jack to keep the hub from spinning. That might work. This isn't going to be fun!
Frank_Jaeger is offline   Reply With Quote
Old 12-17-2013, 12:57 PM   #5
Mikester
Mikester's Avatar
Actually, this is exactly what I was thinking (not the smartass part)... 27mm socket & impact gun is the absolute best way to go.
Word of advice, whatever you do- BE REAL CAREFUL whilst wrastiling with this... The threads are very fine and easily marred (experience)... Although sucky, I do recommend you reconnect the uprights just to keep everything as stable as possible during the fight... Unless you use an impact gun
**One last thing- Axle nuts are ONE TIME USE items... DO NOT reuse them for safety reasons... Rock auto and/or your local Vatozone has them for a couple bucks apiece. Others may chime in and tell you it's fine- Although I'm just an enthusiast like most, I do know this for fact and I assure you that the folks here who ARE certified mechanics will give you the same word of caution.
Best of luck.
BTW Frank, I'd love to see a Youtube video of trampoline & breaker bar... The visual alone is effing hilarious
Mike
Old 12-17-2013, 05:03 PM   #6
xxRaika562xx
xxRaika562xx is an unknown quantity at this point
I had to learn on my own and my personal experience is
Jack up car
Take off wheel
Take out hub cap off wheel
Take out cotton pin
Reinstall wheel
Drop the car
Put a breaker bar with size hub socket
Use a jack and jack up the breaker bar lefty loosey!
xxRaika562xx is offline   Reply With Quote
Old 12-17-2013, 05:04 PM   #7
xxRaika562xx
No back pain and no worries! The jack will do all the heavy work! Hope this help cuz i tried every method without powertool and this by far work like a charm
Old 12-17-2013, 05:09 PM   #8
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
1) The rear axle nuts are 36mm. 27mm is the crank bolt.
2) I have never replaced an axle nut with a new one and never had an issue. What IS important is putting the little keeper piece over the nut and putting the cotter pin back through.
e1_griego is online now   Reply With Quote
Old 12-18-2013, 06:53 AM   #9
Mikester
Mikester's Avatar
Shit- you're right... Clicked as soon as I read that... OP, my bad on the socket size.
I will respectfully disagree regarding reuse of axle nuts; and I have seen plenty of folks do it without issue... Hell, I've done it myself... However, I'm surprised to hear that from you. Once I realized they were one-time use, I never did it again... and put 2 & 2 together as to why I've had a couple come loose on me back in the day. Good thing for retainers/cotter pins
Old 12-18-2013, 08:19 AM   #10
OutToWinPAHC
OutToWinPAHC's Avatar
OutToWinPAHC is an unknown quantity at this point
Send a message via AIM to OutToWinPAHC
Ive never had an issue with am impact gun on these. Ebrake on, car in gead, and crack her loose. Now Z32/R33/R32 front spindle nuts are a bitch
OutToWinPAHC is offline   Reply With Quote
axle, axle-nut, seized bolt
