Old 06-02-2004, 04:59 PM   #1
ankyle62
ankyle62's Avatar
ankyle62 is an unknown quantity at this point
Send a message via AIM to ankyle62
s14 front wheel studs.
i read that the arp studs will not work on the s14 front because the require a larger knurl(.560), which the moroso provides. is this correct? can i use the arp or do i have to get moroso or other brand? if i do, what is a good site to get them from?
i searched but found only a few comments on this and wanted to confirm before i returned the arp ones for the front. thank you.
aim: ankyle62
ankyle62 is offline   Reply With Quote
Old 06-02-2004, 05:22 PM   #2
WilloW
WilloW's Avatar
WilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfection
Send a message via AIM to WilloW Send a message via Yahoo to WilloW
The Moroso knurl is a bit bigger but they will work with some minor grinding IIRC. I think Ace uses them on his car.
WilloW is offline   Reply With Quote
Old 06-02-2004, 05:26 PM   #3
ankyle62
ankyle62's Avatar
but is the bigger knurl required?
aim: ankyle62
Old 06-03-2004, 04:20 PM   #4
ankyle62
ankyle62's Avatar
anyone? i know you s14 people dont all have stock studs.
aim: ankyle62
Old 06-04-2004, 12:15 AM   #5
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
They should even be able to be pressed in with a good hydraulic press, although I'd rather do some "minor" grinding.
I know everyone is going to skip this line:
This is my hub after sitting out for a week after I crashed my black S14, with the Moroso studs:
I run ARP's in the rear, which unfortunately use a differen't thread size.
AceInHole is offline   Reply With Quote
Old 06-04-2004, 07:34 PM   #6
ankyle62
ankyle62's Avatar
ok and with 5 lug and 4 lug, no difference right? i already have the apr because i was not aware of the difference, so now i have the extra studs and different sizes nuts .
and i shop wouldnt look at me stupid if i told them to put them in. they wouldnt say they are the wrong size or anything? because it sounds like a pain in the ass to do. the rears i will do though.
aim: ankyle62
