Old 01-05-2014, 02:57 PM   #1
drifter92
drifter92's Avatar
drifter92 is an unknown quantity at this point
s13 S13 Single Cam to Dual Cam swap chassis harness dash pigtail
This is for anyone doing a DOHC KA swap from SOHC KA. If you wire this onto your car you essentially make the car compatible with any DOHC engine harness in the future.
This harness pigtail will go on your chassis harness under your passenger side of your dash. It connects your ECU/Engine Harness to your dash/cluster.
The SOHC dash harness plug is white, the DOHC plug is brown. When you swap a car from single cam to dual cam, your DOHC engine harness will not plug in to your dash unless you modify the engine harness or the chassis harness. Using this plug you convert your car to DOHC instead of converting your engine harness to a SOHC plug. Any questions please message me.
These are not easy to come by so I figure somebody will need to buy it.
$20 shipped paypal is [email protected]
Instagram: chinowith
https://www.youtube.com/user/untouchable361/videos
drifter92 is offline   Reply With Quote
