SR20 to Z33/G35/VQ Transmission Adapters!
![]() $430 shipped for the adapter plate! Z33 Transmission to SR20 Adapter! ![]() These are the new Version 3 adapters. The new plates have a slight modification which allows a little more clearance with bottom mount turbos. So why a Z33 transmission? Keep reading! The gearing is superior to an SR/KA/Z32 transmission. All of the gears are shorter now so you won't find yourself stuck between 2-3 gear on courses any more. You can now leave it in 3rd gear and rip! Not to mention having a 6 speed transmission that is tough and not made of glass like any SR/KA transmission! This transmission is also significantly stronger. There are local 9 second Z33's that have yet to blow a trans. STOP BREAKING STOCK TRANSMISSIONS! Check out the gear size comparison! ![]() ![]() You will retain your SR Clutch/Flywheel. You do not need a Z33 clutch. What you need for the swap: -Adapter plate -Transmission mount -Driveshaft -Shortened shifter bracket -Modifying Z33 Bellhousing -Stainless steel clutch line. There are many vendors out there who sell these. Pricing: Just the plate and hardware is $430 shipped Additionally other mods are available in stages depending on what you want to pay for. Bellhousing Machining. Not just any machine shop can do this because of the size of the bellhousing. $80 +ship Shifter modification. You send in your shifter and it gets modified then sent back to you. $125 +ship Transmission crossmember. You can retain the original rubber mount(aftermarket mounts will also work). $100 +ship ![]() ![]() ![]() ![]() ![]() A video of the first drive. The two-tone s13 in front has the Z33 trans installed. ImportTuner feature on the car we did the prototyping on. Once this is done, you become rad! Contact: Feel free to contact me through; PM [email protected] 623-fivesixfive-8539 SR20/VQ Transmission Adapter Plate - Maverick Motorsports Thanks, George
-George Marstanovic Sr to VQ transmission adapter, dual caliper brackets, high angle tensions rods, and more! http://www.maverick-motorsports.com/collections/all |
