Old 01-16-2014, 12:22 PM   #1
drugsbunny
drugsbunny is an unknown quantity at this point
weird problem with my headlights s14.5
My headlight fuse keeps blowing, I checked the entire harness and none of the wires are shorting out, I replaced the headlight switch and had no luck, i even tried a higher amp fuse and no luck. The weird part is when I unplug the cluster the fuse does not blow.
Do i need a new cluster or what could possible be the problem ?
drugsbunny is offline   Reply With Quote
Old 01-20-2014, 10:01 PM   #2
ZenkiDeven19
ZenkiDeven19 is an unknown quantity at this point
Is it possible at all that the bulbs your using are just taking to much juice? Or is your fuse to small? Just kind of guessing of what it might be.
Sent from my SCH-I535 using Tapatalk
ZenkiDeven19 is offline   Reply With Quote
s14.5
