Old 01-18-2014, 05:47 PM   #1
QuickSpoolSR
QuickSpoolSR's Avatar
QuickSpoolSR will become famous soon enoughQuickSpoolSR will become famous soon enoughQuickSpoolSR will become famous soon enoughQuickSpoolSR will become famous soon enough
Zeitronix fuel analyzer with apexi power FC
So I plan on switching to e85 this summer and instead of getting a flat tune for whatever ethanol content fuel I fill up with that day, i have heard the zeitronix fuel sensor has an output that can be used with certain ecu's to adjust the fuel and timing maps based on the ethanol content of the fuel. Would this be possible with an apexi power FC?
QuickSpoolSR is offline   Reply With Quote
Old 01-19-2014, 07:40 AM   #2
OnTheChip
OnTheChip's Avatar
OnTheChip is an unknown quantity at this point
NismotronicSA has flex-fuel support. 4 fuel maps with programmable map switching, and MAF to MAP (speed-density) conversion. You would need to add a flex-fuel sensor and Zeitronix ECA to convert the flex-fuel sensor signal to a compatible 0-5V signal.
OnTheChip is offline   Reply With Quote
Old 01-19-2014, 08:38 AM   #3
aga
aga's Avatar
aga is an unknown quantity at this point
no, its not possible with a power fc. if you re gonna use such systems, better switch to a modern ecu like the AEM infinity
My Build
aga is offline   Reply With Quote
