Brainstorming on the clunk from by diff
Hey fellow Zilvians again,
I have a 95 s14 witha redtop sr20. I have what I believe to either be an open diff or possible a 1.5way. Not entirely sure, I bought the car with it. If anyone could tell me what to look for I could find out and post it. Months ago I noticed when I go a little hard around turns it would pop and clunk which from my understanding is normal for a LSD or equivilent. Now I'm noticing a slight knock from the diff between 70-80 mph as well as pretty serious popping when I turn from a complete stop. So basically unless I clutch super slow and not give it gas turning, it will pop a lot. Does anyone think I just may need to change the gear oil or is this diff a possible goner? Any help would be awesome guys. I can post pics if needed. Last edited by Zbythegods; 01-22-2014 at 05:55 PM.. |
![]() Join Date: Sep 2012
![]() Feedback Score: 6 reviews
best thing to do is to pop her open and see whats going on down there. if its serious be happy you caught it in time.. a diff that basically locks up/jams is scary as hell going even 40 mph
#3 | |
![]() Join Date: Nov 2011
Some diffs like to clunk at low speed, tight turns but knocking at highway speed aint right. Check out what's going on in there.
#5 |
Hmmmm. Listen guys I really do appreciate that. I'm going to check the subrame bushings first. I hope to the gods it is that but knowing my luck it might not be. What I noticed is it does get worse if I hit a bump on the highway...might be the bushings after all. I just hope I can hold the fort down until this weekend lol.
#8 |
![]() Join Date: Jun 2007
Well, the one thing that I haven't seen is anything you happened to notice when you GOT UNDER THERE AND LOOKED AT EVERYTHING BEFORE STARTING A THREAd! But seriously, if you have the sound isolated down to the diff area; the problem could very well be obvious... Just sayin'
![]() Check the nuts/bolts holding your axles to the diff... and the DS nuts/bolts... as well as the other mounting points & the bushings. Could just be some slop due to loose/missing hardware... Also verify the axle nuts are securely fastened thru the rear hubs... Might be a little easier to help if you can tell us for sure what the problem is NOT... Yano?
#9 | |
