Old 01-22-2014, 02:26 PM   #1
DKnissanman
DKnissanman is an unknown quantity at this point
Exclamation leaking rack, do i fix or just keep on going
Obviously its a problem but right now cash flow is a little low so installing it will be a little troublesome
my outer tie rod ends are however broke along with inner so i was planning to just install them and leave the pinion leaking
my question is, what damage is leaving the pinion going to do if i can just keep adding atf to the reservoir?
inner tie rods are on the rack i understand just need some enlightenment.
DKnissanman is offline   Reply With Quote
