![]() Join Date: May 2009
FS/FT: 1JZ Parts (Harness, ECU, Twin Turbos, MAP, Oil Pans, etc)
Ok, I'm parting out the spare 1JZ I have as well as parts that I won't need since I'm using a megasquirt to power this bad boy. Parts that I have that will be up for sale are as follows.....
1JZ Head w/ cams, OEM valves, OEM Springs, OEM Retainers, OEM cams - $250 1JZ Soarer ECU - $250 1JZ Soarer Harness - $200 2JZ-GTE Map Sensor - $100 1JZ Intake Manifold (comes with IACV) - $200 1JZ Twin Turbos (I have 2 sets) - $200 1JZ Rear Sump Oil Pan Setup (Lower Pan, Upper Pan, Pickup tube, and shield)- $350 ($600 new) 1JZ Used Oil Pump (I have 2 of these) - $100 1JZ Block With Crankshaft (#6 spun a bearing, could be easily repaired but I don't need it) - $200 1JZ OEM Rods and Pistons set w/ used rings (set of 6 but one rod was spun and needs honed or replaced) - $200 Only things I would be interested in taking for trades will be R154 parts (tranny, bellhousing, clutch setup, flywheel, shifter extension) or 1JZ parts (turbo manifold, turbo, wastegates, BOV, etc). Thanks, Ben |
