Old 01-23-2014, 03:09 PM   #1
s13havok
s13havok is an unknown quantity at this point
s13 low compression
Ok I've got a 91 s13 with a sohc motor in it. I ran a compression test and found out that cylinder 4 is running at 60 psi. The car has an exhaust leak out of the manifold but surprisingly doesn't run all that bad considering. Is there a way to test whether its something other than the exhaust leak causing the low compression? If anyone has any ideas im open to suggestions. thanks
s13havok is offline   Reply With Quote
