Old 02-06-2014, 06:05 AM   #1
GoingHam
GoingHam is an unknown quantity at this point
++++++++demod sale! Turbo, long block, bov, intercooler etc
TAX REFUND MOD SALE!
Garrett GT2871R .86 Exhaust W/ Greddy O2 Housing Welded to it, No shaft Play, 700
All oil and water lines needed for this turbo setup including block and turbo fittings and the BB Restrictor (.032") All parts are Earl's - 100
SR20DET HKS Exhaust Manifold modified to run an external 2 Bolt Wastegate - 700 (retails for 1000)
SR20DET CAS (fairly new my original one cracked) - 100
SR20DET Igniter Chip - 40
Exedy Stage 2 Three Puck Clutch SR20DET 50% remaining - 150
Circuit Sports Coolant Catch S13 - 40
Circuit Sports BMC Heat Shield - 20
SR20DET coil Packs w/ Harness - 150
SR20DET Starter - 80
HKS Honeycomb Filter w/ Adapter - 70
Blitz FMIC - 300
XSPower 38mm Wastegate - 20
Greddy Type RZ Blow Off Valve (real) - 100
Aeromotive FPR with -4AN inlets and outlets and ISIS adapter to stock SR/KA Rail - 220
Redtop SR20DET LONG BLOCK - 600
Has a tap in the top end, sounds like 2 collapsed lifters, no metal shavings and still has oil in it and filter from last event it was driven at to show no metal shavings. Motor itself has less than 36,000 miles on it, i took it out of the 180sx it came from myself at Elite JDM
i have more pics if needed, prices really aren't that flexible i think they are fine where they are at. If i dont respond to your PM immediately, sorry, as per forum rules i cannot leave my e-mail or phone number so allow some time for a response.
thank you.
GoingHam is offline   Reply With Quote
