Old 02-23-2014, 01:48 PM   #1
gtr011
gtr011 is an unknown quantity at this point
KA built s14 ka24de
i have a s14 built ka. bc forged rods rated to 200hp a rod so 1000hp rods, je 11:1 pistons .020 over, bc 272 cams and dual valve springs new valve guides ported head and milled flat and checked for cracks. the block was bored to the pistons and decked, crank was balanced and polished. acl rod bearings arp main and rod and flywheel bolts. all new oem gaskets and cosmetic head gasket new AMS high oil pressure pump new oem water pump comp stage 4 6 pluck clutch rated to hold 500 foot pounds of tq. comp 11 pound flywheel from z1. everything on this build is brand new and 0 miles i started to build it and then went rb so no need for this. all the work was done by tpr so it was done right. the motor will come with a full standlone ecu megasqurt pnp2 i have it running on my stock ka no problems and its on a map sensor no more maf. im going to let this build go alot less then what it cost to build something like this. i will also add a few extra parts and most of the parts to turbo this motor too. I WILL NOT TAKE TRADES UNLESS ITS FOR OTHER RB25 PARTS. Dont make dumb offers and waste my time i have no problem keeping this motor. MAKE ME AN OFFER I HAVE EVERY RECEIPT FOR THIS BUILD. im sure im forgetting things but this is one build that will last.
gtr011 is offline   Reply With Quote
240sx, built, ka24de, ka24det, s14
