Old 02-23-2014, 08:24 PM   #1
dangarnett
dangarnett's Avatar
dangarnett is an unknown quantity at this point
s13 1989 240sx Type X - Must Sell
SOLD
I have tried to hold on to this for so long, but sadly I have to sell her this time for sure. I am moving and need to sell. I need to sell it pretty fast, so please make any offer if you are interested.
MORE PICTURES ON PAGE 2
Mods
Front clip s13 with Sr20det black top
Hot tanked
New valve stems
New valve jobs
3 angle valve job
New oem piston rings
New rods and main bearings
New thrust washers
New OEM Nissan rebuild gasket
New water pump
GT2871R Garret Turbo
Toda camshafts 264
Tomei rocker arms stopper
Brian crower valve springs and titanium retainers
Nismo 555c.c injectors + new orings
Walbro fuel pump
Brand new OEM fuel rail
Aluminum hot pipe
Hks ssqv blow off valve (adjustable version)
Apexi Versa Cruise grounding kit
NGK iridium spark plug 7
Tomei oil cap
Greddy turbo outlet
Koyo Aluminum radiator
Greddy radiator cap
Samco radiator hose
Nismo thermostat
Sard fuel regulator
Apexi metal head gasket 1.1 mm 87 bore
ARP head studs
Uras Racing clutch
Tomei short shifter
Tomei Valve Spark Plug Cover
Greddy oil cooler
Greddy oil filter
Greddy v-spl front mount intercooler
Greddy oil pan
Circuit sport turbo lines
S14 water outlet
Oil catch can
Greddy cooling panel
Custom aluminum intake pipe
Apexi Cone Filter
Apexi WS catback
Trust down pipe
Test pipe
Brand New Optima Yellow Top Battery (Relocated in Trunk)
Suspension
Work CR KAI 17x9+17, 18x9.5+12 (10mm spacer in the rear to make it +2)
Federal 595 215/45/17, 225/40/18
Brembo calipers front and rear
Power slot front rotors
300zx e brake set up
Tein super drift 10k/8k
Tein tie rod + ends
Silk Road tension rod
S14 5lugs hubs
S14 front lower control arm
SPL fender braces
Shakitto plates
Nismo power brace
Rash Facture C-Pillar bar
Cusco strut bars F+R
Cusco ruca’s
Cusco toe arms
Kazama subframes
Volk racing lug nut extended
Nismo 60mm wheel studs
Cusco 2way LSD + Cusco LSD oil
Super Hicas rear sway bar 21mm
Brand new Power Steering rack & Fresh Alignment after.
Exteriors
180sx OEM Kouki bumper
180sx OEM kouki side skirt
180sx OEM kouki rear valances
180sx OEM kouki wing
180sx OEM Kouki taillight
180sx optional Rps13 tail light center
Ganador Style Mirrors
H4 head lights
Brand new Headlight switch
Interior
Apexi EL2 gauges: Boost, oil press, ex temp
Apexi gauge unit controller
Apexi avc-r black edition
Apexi turbo timer
Recaro seats
Japanese Maziora steering wheel w/ Nardi Horn Knob
Tomei shift knob
Hand Made Red Stitch Shift Boot and center console arm rest.
Sony head unit
Price: SOLD
Need sold fast, so make an offer.
If you're actually interested, I'll tell you more about the car, or you can come see it. Located in San Diego.
Email me for fastest response: [email protected]
It has been very lightly driven over the years for a daily driver. Less than 20,000 miles in the 4 years i've owned it. Very well taken care of. The chassis is at 189,000, engine probably about 25,000.
Smogged until June.
*Things to consider
This is a heavily modified car, please be experienced at driving one if you are interested in buying it. It has a 2-way Differential, so it's clunky when turning. Also the clutch is extremely harsh, it's a super-single plate clutch, so it makes noise when you press it. This is not a first car, so I would not suggest showing up with your mom to test drive it.
No heat or A/C.
The head lights flip up, but don't flip down.
More Pictures!
dangarnett is offline   Reply With Quote
Old 02-23-2014, 08:45 PM   #2
DennisS
DennisS is an unknown quantity at this point
Beautiful car. bump for you
DennisS is offline   Reply With Quote
Old 02-23-2014, 09:37 PM   #3
Bleakley
Bleakley is an unknown quantity at this point
Oh my Goohd!
If I could multiply some of the cash I have by 5-10
I would not hesitate to buy...
Bleakley is offline   Reply With Quote
Old 02-24-2014, 12:10 AM   #4
fsuarez
fsuarez's Avatar
fsuarez is an unknown quantity at this point
Send a message via AIM to fsuarez
What recaros seats do you have and how low do they sit?
fsuarez is offline   Reply With Quote
Old 02-24-2014, 12:48 AM   #5
nemesisZ33sx
nemesisZ33sx's Avatar
nemesisZ33sx is an unknown quantity at this point
beautiful car bump!
nemesisZ33sx is offline   Reply With Quote
Old 02-24-2014, 08:16 AM   #6
DPS14
DPS14 is an unknown quantity at this point
Amazing car. Definitely interested. Maybe I missed it in the mod list but what engine management are you running? Also, understand it has no A/C or heat... was the blower motor/heater core removed?
DPS14 is offline   Reply With Quote
Old 02-24-2014, 09:43 AM   #7
k240sx
k240sx is an unknown quantity at this point
Nice looking S13 !what color is ?
Do u think you will part out your car ?like your type X wing ?
If so pm me a price shipped to 94538 thx
Glws
k240sx is offline   Reply With Quote
Old 02-24-2014, 10:41 AM   #8
akaina240
akaina240 is an unknown quantity at this point
sent a pm, im local
akaina240 is offline   Reply With Quote
Old 02-24-2014, 11:11 AM   #9
dangarnett
dangarnett's Avatar
It was rom tuned by the previous owner with all the mods on a T25. It has a 2871r atm with the boost turned down to about 7psi. I have a power FC I can include for extra if the buyer is interested.
Also Note: I am busy all week. I won't be able to set up appointments to see the car until saturday and sunday. 3/1, 3/2. If you have time you'd like to see it, pm/email me the time and I will put you down. Thanks.
Old 02-24-2014, 12:46 PM   #10
nosajton
nosajton is on a distinguished road
if its been rom tuned, and located in San diego, odds are its got my tune. If so or If not I can reflash it for the 2871r so you can turn the boost up if interested. May appeal a bit more with double boost. If it in fact is my board I can give you a sweet deal! GLWS
04 G35, Kinetix Plenum, Borla Ext, JWT Intake, custom ETG ECU Reflash.
nosajton is offline   Reply With Quote
Old 02-24-2014, 02:41 PM   #11
dangarnett
dangarnett's Avatar
The car was originally from LA, and it was done by the previous owner. I'll keep it as is, but anyone interested in buying it can see this guy after ^.
Or I have a Power FC that I can throw in for extra, but it would need set-up for the car.
Old 02-24-2014, 02:47 PM   #12
dluevanos01
dluevanos01 is an unknown quantity at this point
The con of healights not going down, is a faulty/dirty light stalk. There is DIYs onlineon how to clean it or simply replace it. take less than 30 mins.
If this had a stock KA, I would buy it as a daily. I can't have 2 Sr, type x s13s.
GLWS and that an great price.
IG: @te37_daniel
Build thread
dluevanos01 is offline   Reply With Quote
Old 02-24-2014, 03:44 PM   #13
dangarnett
dangarnett's Avatar
Nope, I replaced the light switch/stalk with a brand new one. Swithced out all fuses and relays, still no go. I've heard it could be the headlight Timer or TCU.
Old 02-24-2014, 04:59 PM   #14
OiyItsC4ry
OiyItsC4ry's Avatar
OiyItsC4ry is an unknown quantity at this point
ouuuuuu kill em! glws bro!
OiyItsC4ry is offline   Reply With Quote
Old 02-25-2014, 01:59 AM   #15
JayDee M Rolly
JayDee M Rolly's Avatar
JayDee M Rolly is just really niceJayDee M Rolly is just really niceJayDee M Rolly is just really niceJayDee M Rolly is just really niceJayDee M Rolly is just really niceJayDee M Rolly is just really niceJayDee M Rolly is just really niceJayDee M Rolly is just really nice
Send a message via AIM to JayDee M Rolly
hope i win the lotto tomorrow
free bump
-Lloyd
Originally Posted by Taniguchi_Is_#1 View Post
are you an angel? because i want to put my penis in your vagina.
http://yourenotdown.net/
JayDee M Rolly is offline   Reply With Quote
Old 02-26-2014, 02:53 PM   #16
dizzariot
dizzariot's Avatar
Trader Rating: (47)
dizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfection
Feedback Score: 47 reviews
Wow. I hope to see this driving around SD soon. I'll be back there in two week's time. GLWS.
The mark of a true sucka: 'RARE JDM' & 'OLD LOGO NISMO'
dizzariot is offline   Reply With Quote
Old 02-26-2014, 03:13 PM   #17
burgundyandblue
burgundyandblue's Avatar
burgundyandblue is an unknown quantity at this point
If u decide to part out I'm interested in all your type x parts. Just got my refund so I got Cash in hand lmk! 661 877 1123
burgundyandblue is offline   Reply With Quote
Old 02-27-2014, 10:42 AM   #18
schoja
schoja is an unknown quantity at this point
It's...It's just so clean
schoja is offline   Reply With Quote
Old 02-28-2014, 07:41 AM   #19
JF_OverBoosted
JF_OverBoosted's Avatar
JF_OverBoosted is an unknown quantity at this point
Jesus... Simple n Clean
GLWS.
JF_OverBoosted is offline   Reply With Quote
Old 02-28-2014, 10:48 AM   #20
youradumb1
youradumb1's Avatar
youradumb1 is an unknown quantity at this point
wish you were east coast
great looking car glws
just better than you
youradumb1 is offline   Reply With Quote
Old 02-28-2014, 02:41 PM   #21
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
bump for what all 240s should strive to be! i just hope whoever buys it takes good care of it! would hate to see something this nicely built go to some jackass whos gonna trash it!
Old 02-28-2014, 05:50 PM   #22
dangarnett
dangarnett's Avatar
I had this for sale a few years ago and I had 2 different kids show up with their moms and wanted to buy it for their first car. I cried inside, and couldn't let it go to them. I will miss this car, please buy it before I refuse to sell it again for the 4th time.
Old 02-28-2014, 09:19 PM   #23
Drift626
Drift626 is an unknown quantity at this point
I definitely agree with you! Would love to own this car but unfortunately I am new in the game and I'm lacking an extra 10.5! GLWS
Drift626 is offline   Reply With Quote
Old 03-01-2014, 02:04 PM   #24
Philthese93
Philthese93's Avatar
Philthese93 is an unknown quantity at this point
I remember your picture from Reddit. BUMP!
Philthese93 is offline   Reply With Quote
Old 03-03-2014, 08:34 PM   #25
bmcateer989
bmcateer989 is an unknown quantity at this point
just to make sure, it is legally smogged in california right? i mean its not that important but this being smog legal would just be the cherry on top. im semi-local and extremely interested
bmcateer989 is offline   Reply With Quote
Old 03-04-2014, 04:54 PM   #26
foreverdark
foreverdark's Avatar
foreverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfectionforeverdark is close to perfection
^LOL!
Clean car man. Everything that a s13 should be! GLWS!
foreverdark is offline   Reply With Quote
Old 03-05-2014, 02:27 AM   #27
eek
Trader Rating: (29)
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
Feedback Score: 29 reviews
ROFL What a waste it would be to go to an owner like that. Anyhow well done on the car sir. GLWS Hopefully you can find a GOOD home for it.
eek is offline   Reply With Quote
Old 03-05-2014, 01:23 PM   #28
bmcateer989
how is asking if its smogged make me a waste of an owner?
Old 03-05-2014, 01:25 PM   #29
bmcateer989
me asking if its smogged means im gonna break the car or something? hell no. just a curious question to something i saw in the add.
Old 03-05-2014, 10:06 PM   #30
badboypmt187
badboypmt187's Avatar
badboypmt187 is an unknown quantity at this point
my 89
Attachment 67754Attachment 67755 that's sweet!!!!!!!!!! heres pic's of mine!
badboypmt187 is offline   Reply With Quote
