Old 06-10-2004, 12:19 PM   #1
Uniac
Uniac is an unknown quantity at this point
Send a message via MSN to Uniac
Another 91 Ka problem
Just finnished the dohc swap in my 90. Start it up, first try, idles for 5-15 sec and dies. Now if i sit there and free rev it, it'll run, but it dies as soon as i get off the gas. It's also backfiring like crazy.
Here's the setup: AAC and FPR only and a short ram intake.
please help me keep it running.
thanx
Uniac is offline   Reply With Quote
Old 06-10-2004, 02:10 PM   #2
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
umm.. check..umm.. hmm.. check ecu for codes? maybe ur timing is bad? check the FSM for the back firing problem.. if u get backfire, you arent getting enough air into ur engine.. check the throttle body, and intake. buy some TB cleaner, and spray both the suckers down, and make sure none of the vacuum hoses connected to the two are leaking. Hope this helps.
~DJ Sunrise
DJ_Sunrise is offline   Reply With Quote
Old 06-11-2004, 12:02 AM   #3
KevinsS13
KevinsS13 is an unknown quantity at this point
Send a message via AIM to KevinsS13
How about trying the fuel filter? &Fuel pressure? Let us knowwhat it ends up being? Mine ran like really horrable before and it was because of the PCV valvle, its less the $10 to replace it yourself. Its tuff to find and reach with your hands!
KevinsS13 is offline   Reply With Quote
Old 06-11-2004, 12:28 AM   #4
Uniac
fuel filter is new 2 months ago, maybe 5000km on it, 300zxtt filter... i'll try clamping the return line to boost the pressure, see what that does.
I took out the secondary butterflies, think this might casue somthing?
i'll let you know what i find out that doesn't fix it tomarrow, it's late now. I've had enough for 1 day
Old 06-11-2004, 09:38 PM   #5
Uniac
well it seems to be backfiring thru the intake and there is a whistle on the inside of the intake mani(side closest to the block) I guess i have a leak in th aac hardline or somthing. I'll pull the entire unit and see whats what.
Old 06-12-2004, 10:19 PM   #6
GlacierFreeze
GlacierFreeze is an unknown quantity at this point
Make sure the intake manifold bolts, holding the top and bottom half together, are tight.
You =
Me =
GlacierFreeze is offline   Reply With Quote
