Old 03-07-2014, 03:17 AM   #1
FCDRIFT
FCDRIFT's Avatar
FCDRIFT is close to perfectionFCDRIFT is close to perfectionFCDRIFT is close to perfectionFCDRIFT is close to perfectionFCDRIFT is close to perfectionFCDRIFT is close to perfectionFCDRIFT is close to perfectionFCDRIFT is close to perfectionFCDRIFT is close to perfectionFCDRIFT is close to perfectionFCDRIFT is close to perfection
Smile FS: 1989 black 240sx Hatchback KA24DE well maintained
hello zilvia,
looking to sell my s13 hatch which ive owned for the last 8 years. i have modified it slowly for reliable track use. i would consider this a mildly modified s13 for track use thats street legal. its a 89 model with a dual cam swap. base model, came factory with manual windows, heater, and no A/C, one of the lightest s13s nissan made. chassis has roughly 181k miles, motor is closer to 125k. has been regularly maintained, engine oils, transmission oil, diff oil, coolant flush, etc has all been done within the last 6 months. tags are up to date with no past due fees etc.
as you can tell, its a function>form type of car. suspension is setup with power in mind and is one of the easiest and most reliable s13 out there. if you are looking for a turn key car, that you can drive to track, have tons of fun, and not have to take out a second mortgage on ur house, then this is it.
here is a short list of the mods i can remember, im sure theres things that i left out.
Mods
spark plugs, cap and rotor, NGK wires
OEM thermostat and radiator hoses
OEM all heater hoses
OEM water pump and thermostat
Koyo aluminum radiator & cap
Walbro fuel pump
Blueprinted and matched injectors from RC enginnering
Exedy Stage 1 clutch & pressure plate
Brake Master and Slave
stainless steel clutch line
AEM Intake
DC carb legal headers
Battery
Suspension
XXR 513 15x8+0 (full set)
TE37 Knock offs 15x8+0 (pair)
Dunlop Direzza DZ101 205/50/15
Stainless steel brake lines
new rotors all around
Porterfield R4-S brake pads all around
Stance Coilovers
Tein tie rod + ends
Battle Version tension rods
Megan ruca’s
Megan toe arms
Megan traction rods
Welded diff
Fresh Alignment after.
Interior
Prosport electronic water temp gauge
Prosport electronic oil temp gauge
Prosport electronic oil pressure gauge
Kenwood Headunit w/ipod connect
Infinity component speakers w/tweeters
Rockford Fosgate amp
Rockford Fosgate 10" subwoofer w/custom mounted box
Nagisa seat rails
***sparco seat not included with sale***
Price:$3800 OBO
not looking for any trades.
If you're interested, I'll tell you more about the car, or you can come see it. Located in Oxnard CA 93033.
for fastest response, text: 562-883-8838
FCDRIFT is offline   Reply With Quote
Old 03-10-2014, 01:13 AM   #2
91cupcake240
91cupcake240's Avatar
91cupcake240 is an unknown quantity at this point
Bump
Sent from my SM-N900T using Tapatalk
_____________________________
91cupcake240 is offline   Reply With Quote
drift, hatch, s13, track
