Old 06-12-2004, 02:40 PM   #1
damienknight
damienknight is an unknown quantity at this point
240sx coolant boil problem
I have a 1990 240sx automatic. I have the stock KA24E engine in it. I'm going to convert it to manual, but first I need to figure out how to fix my damn problem. Here's the deal:
When I drive it around, the coolant will overflow in to the reservoir and start to boil. I've alread tried flushing the coolant system, and when I refilled it the radiator only took 4 quarts of fluid, instead of the specified 7 1/4 quarts. I tried running the engine with the cap off to see if there was air in the system, and the coolant started overflowing from the radiator after idling for less than a minute.
I'm just looking for advice as to what steps to take next, if anyone's had this problem that would be great. I'm afraid it might be the head gasket, but I want to try other things first, thanks.
damienknight is offline   Reply With Quote
Old 06-12-2004, 07:50 PM   #2
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
Did you turn on the heater while doing refilling? Also, is your thermostat opening? Is there any coolant coming out of the weep hole on the water pump?
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
Old 06-13-2004, 12:01 AM   #3
damienknight
yeah, i turned the heat all the way up. the thermostat is fine, it was just changed, and no coolant leaks.
Old 06-13-2004, 12:15 AM   #4
element240
element240's Avatar
element240 is an unknown quantity at this point
Send a message via AIM to element240
make sure your radiator cap isn't faulty...
also, some of the coolant stays in the block which might contribute to why you only needed 4 qts ... i think there is a coolant drain plug on the block , or at least the fsm says so for the SR
element240 is offline   Reply With Quote
