03-12-2014, 10:13 PM | #1 |
Rb20 Headgasket question
Alright so I am on my 2nd rb the motorset I just bought I am doing a basic rebuild on it, gaskets mainly. that and studs main and head. but anyway the motor passed a leakdown test and I am wanting to replace the 20+ year old head gasket since its not blown I am still sending the head to get resurfaced or would I even need to? and could I just get all of the gasket material off the block instead of having it decked? Its not a metal head gasket which I know from my prior ka builds you need both head and block machined so the hg will seal properly.
Anyway I am curious about that and I have used Copper spray on hgs before but never known anybody who has had any problems in the long run. and The gasket kit is not Ebaycrap. I actually got the nissan part number and bought it from the nissan stealership. |
03-19-2014, 11:55 AM | #2 |
You may not have to get anything resurfaced or decked, I would have the head cleaned and checked for true-ness as well as the block, if neither are warped or cracked you should be good. Im goin in a similar route with my rb20 nothing radical just wanting a solid engine. We tore the engine down and checked everything to be sure everything is with in spec. according to the FSM. While you have it tore down that far I would go ahead and get the crank collar upgrade as well and save some future oiling issues.
