Old 03-18-2014, 04:57 PM   #1
Frankiejay420
Frankiejay420 is an unknown quantity at this point
Angry S13 ka24de swap 12V to coil no spark
Ka24e to ka24de swap, has fuel but not getting spark.. 12 volts to the coil but nothing coming out.. what could it possible be? the ECU I got from the guy two weeks later hoping he didn't drop it or anything..
Attachment 68268
Attachment 68269
I did re pin the dash connector, water temp, tech, speedometer, a/c, ignition start signal and grounded the black wire to two ground wires from the actual plug..
Attachment 68270
Attachment 68271
Attachment 68273
Attachment 68274
Attachment 68275
Attachment 68276
Even bought another coil thinking the first one I just bought was a bad coil, should I try swapping ECU's? How can I use my DMM and test the dizzy? or CAS? Module? I know ima need to swap the tach if I want it to work, or do I need a dohc tach to complete the circuit or something because I see that same wire (tach) runs to the relay by my coil doesn't the coil have a pulse? well this is my first swap so bare with me please.. been searching and searching and seem to not find much..
Attachment 68272
Frankiejay420 is offline   Reply With Quote
