03-22-2014, 10:56 PM | #1 |
Cam Angle Sensor good or bad?
Ok so my situation right now is my s13 sr20det in my s14 is turning over but wont start. Its not getting spark to the plugs and injectors are not spitting fuel. I do have fuel pressure and fuel pump is turning on. Im trying to test my CAS to see if it went bad or not. My question is that when I spin my CAS by hand (still plugged into the harness) my fuel pump starts sending fuel to the rail as I continue to spin the CAS. Does this mean my CAS is working properly and that Im not getting spark for some other reason? Or could my CAS still be bad even though its telling the fuel pump to send fuel.
A friend said it could be that I don`t have an engine to chassis ground so I`ll be getting that by Monday. But I didn`t think a simple engine to chassis ground would cause no spark/injectors not spitting fuel. Any advice/help is appreciated guys. Thanks. |
03-22-2014, 11:10 PM | #2 |
Trader Rating: (58)
Feedback Score: 58 reviews
The CAS can still be faulty, and allow the pump to prime.
With that considered, did it run previously or did you get it in a non running condition?
03-22-2014, 11:13 PM | #3 | |
From what I was told the motor was in running condition when I purchased it. And it's the same CAS that was on it so I assume it was in working condition. Sent from my SAMSUNG-SGH-I337 using Tapatalk |
03-22-2014, 11:25 PM | #4 |
i have the problem of the car turning over and not starting too.
except.... mine started today. but... my friend touched the rad support, got shocked by the car, and i now have this problem. i'm lost as to where to start.... the SAME dang day... the car starts and runs fine to just turning over. |
03-22-2014, 11:39 PM | #5 | |
Trader Rating: (58)
Trust me when I say If I had a dollar for 'perfect condition parts' that were fubar or wrong, I'd be driving a much nicer car. Check the FSM on troubleshooting the CAS too. All considered though, if the engine was running and now it's in a new chassis, and you don't have fuel or spark, I'd check the harness grounds behind the head first.
03-22-2014, 11:47 PM | #6 | |
And yea I thought spinning the CAS was only way to trouble shoot it guess ill look on fsm for diff ways. Sent from my SAMSUNG-SGH-I337 using Tapatalk |
03-23-2014, 06:43 PM | #9 |
Trader Rating: (58)
I'm willing to bet it is something as simple as a ground. Being you have a good W/S harness you can eliminate alot of troubleshooting that many need to do with crappy harnesses.
You would need to check voltages from the CAS to makes ure they are in spec too. Another quick/dirty way to test is to pop the cover off and give it a snif (yes, smell it)...if you smell burnt electronics, you can almost 95% of the time consider it toast
03-23-2014, 06:46 PM | #10 | |
03-23-2014, 10:12 PM | #12 |
injectors werent spitting fuel so no fuel sitting in there. no spark and or injectors throwing fuel into chamber. i`ll be doing more test this week when i have the time.
03-24-2014, 02:53 PM | #13 |
Cranking without a large gauge engine to chassis ground can fry lots of things.
NismotronicSA - Speed-Density Tuning for Nissans |
03-24-2014, 05:54 PM | #15 |
ok well what i did get around to was testing the actual harness plug to the cas. im getting a 5.1, 5.1, 11.7 and good continuity on the ground. so im guessing the harness is sending the proper voltage to the cas. right? but im Still not sure where to touch my multimeter probes on the CAS while its connected to harness to test to make sure its getting proper volatage while i spin cas by hand.
