03-23-2014, 12:59 PM | #1 |
Clutch Pedal Vibration, Grinding sound?
Clutch pedal vibrates while engaged, also noticed a grinding/vibrating sound.
the vibrations,sound changes with the rpm, as rpm goes up the vibration/sound gets louder. it seems to get better after a few minutes of driving. i think the vibration/pedal is still there if you go high rpms though like 4000 and up, but not as bad as in the morning. also noticed pedal is a tiny bit more soft on cold start, but gets more stiff after a few minutes of driving. just changed new master , slave, and a steel braided clutch line. any ideas? weird that it gets better after few minutes of driving. |
03-23-2014, 02:39 PM | #2 |
SR ? KA ?
Sounds like you need to pull your transmission and check the throw-out bearing. Expect to replace it while you are in there (order a new one in advance) might as well. good time to replace the clutch also. And the pivot ball (buy a nismo). |
03-24-2014, 01:02 PM | #3 | |
This is a SR, just recently did a clutch job, with a RPS Streetmax Clutch/pressure plate, resurfaced oem flywheel when we were doing the job, the pilot bearing was cracked and broke off LOL. but we replaced that with a new one, but we noticed the input shaft/sleeve where the TOB goes on was also cracked, hmm maybe this was the problem? maybe after a while it just completely cracked. the weird thing is, its worse in the morning, but after driving for a few minutes, the vibration/sound is almost completely gone, unless you are in high rpms. |
