03-24-2014, 06:12 PM | #1 |
SR20 starts with no fuel, doesn't start with fuel
I have an enthalpy ECU.
Today, i installed another FPR from a nismo adjustable because i didn't have the tool to test the psi. the car starts because of the flooded cylinders. (with the FP fuse pulled) but when i put the fuse back, and try to start the car, it just turns over and over. injectors have been tested and cleaned by dwerks. so they are good. it's a stock FPR, but i dont feel the likely hood of it being bad is the problem. any other solutions? |
03-24-2014, 06:37 PM | #2 |
Hey dude. I had a similArissue, unplugged fuel pump fuse and it actually started and idled but wouldn't drive. Put fuse back in and it died.
Turned out to be a massive vacuum leak. So either check ur maf and wiring or boost leak test all your couplers
03-24-2014, 06:56 PM | #5 |
Do you have a torn Oring on your injectors? That would cause both a fuel and a vac leak... Enough fuel to "flood" the engine.
03-24-2014, 09:15 PM | #7 |
03-24-2014, 10:19 PM | #8 |
Ok well you understand a vacuum leak doesn't mean vacuum lines, it means your car is sucking in unmetered air.
And even though it was running last week your symptoms sound like a major vacuum leak. So once you finish the boost leak test, then you can say that wasn't the issue
