Old 03-26-2014, 01:03 PM   #1
BlewByYou
BlewByYou's Avatar
BlewByYou is an unknown quantity at this point
Rb25/26 Engine
This sale is for the ENGINE ONLY!!!
NO Manifolds, NO Valve Covers
Brand New Setup never cranked. Install it, Prime it and go!
-Series 2 RB25DET (0 Miles)
-Honed and Hot Tanked
-Over $1,000 in Polydyn oil shedding and friction
coatings (Block, Pistons, Timing gears, etc.)
-RB26 Internals
-ACL Bearings Main/Rod
-ARP Main Studs
-ARP Rod Bolts
-10an Block Fittings
-New OEM oil pan w/10AN Bung
-New N1 oil pump
-New N1 water pump
-ARP Head Studs
-3 Angle Valve Job all new seals
-HKS cams
-Muti Layer head gasket
-Tomei Oil Restrictor
-Rear Head Oil Drain kit
-Ngk Spark Plugs
-Nismo Timing Belt
-New Timing Belt Tensioner
-Cometic Gasket Kit
-Quest Alternator w/Custom bracket
-HKS belt
-Raw Brokerage Exhaust Stud Kit
-Raw Brokerage Oil Filter Stud
Well Over $7,000
Houston,Tx
$3000 or $3200 Shipped
BlewByYou is offline   Reply With Quote
Old 04-30-2014, 10:54 PM   #2
jchandler21
jchandler21's Avatar
jchandler21 is an unknown quantity at this point
would you consider selling the quest alternator and bracket seperately?
jchandler21 is offline   Reply With Quote
Old 05-01-2014, 09:46 AM   #3
BlewByYou
BlewByYou's Avatar
Everything is sold
