Old 03-27-2014, 05:26 PM   #1
nissangooroo
nissangooroo's Avatar
nissangooroo is an unknown quantity at this point
KA s13,s14 KA Parts and more
Update: Located in Yakima,WA
FOR WA Residents
Willing to ship and Willing to Travel as far as north seattle its not a problem.
CAN take trades. Will ship most items that weigh under 20lbs. Thank you and prices are negotiable (OBO) but consider GAS or Shipping if your not Local.
FOR ZILVIA Members i can ship most of the following
s13 chuki turn signals 20$
s13 pop up plastic buckets 10$ ones broken
KA24DE s13 crank 40 $ SOLD
S14 ka dizzy 40 $ SOLD
s13 6 bolt axle.... 35$
S13 Dual Cam WATER pump 25$
Shifter Rubber Boot the little one NEW 10$ NISSAN OEM
Stock S14 KA Cams 45$
Stock s13 KA cams 248/240 oem) 45$ SOLD
S14 Ka fuel rail no injectors HAS EMISSIONS HOSES 20$ SOLD
S14 and S13 intake manifolds 35$ for S14 and 25$ for s13
S14 and S13 exhaust manifolds 25 $ each S14 SOLD
S14 Ka head 35$ 80k mile head sat for a few years
S13 Head 35$ SOLD
S14 Ka Valve cover 35 $
Rear Main Seal set 10$ NEW
Altima or s13 Fuel rail i forget just the rail no injectors or harness 15$
S13 Dual cam alternator and power steering pump 25$ for the alternator and
35 for the Pump BOTH SOLD
ABS HICAS Brake Rotors (a few mm bigger) FRONT AND REARS 5$ each
Engine Cross member NO MOTOR MOUNTS 30$ SOLD
2 S13 ABS Knuckles 30$ the pair SOLD
Have s14 block.
Clutch fan 10$
S13 KA Dual Cam Igniter 10$
Front S13 Sway Bar 25$
5 Speed rubber boot gasket 10$ NO Rubber Boot
Various Bolts and pieces Timing Chains, Sprockets Brackets and other small
items AND Internals
ALSO HAVE HICAS Steering ACCESSORIES AND STRIPPED HICAS REAR SUBFRAME
Have MORE accessories and Pulleys ECT ECT
IF IM FORGETTING ANYTHING THATS POSTED JUST LET ME KNOW THANX
nissangooroo is offline   Reply With Quote
Old 03-27-2014, 05:28 PM   #2
nissangooroo
This is my first for sale post so if i did anything wrong let me know thanx
Old 03-27-2014, 10:07 PM   #3
nissangooroo
bump Prices are negotiable and i have alot of small parts
(O=O/ RPS13 \O=O)
parts for sale
