Sputtering At Boost
Hi, just recently bought a S13 coupe with a blacktop SR20DET. Internals are all stock AFAIK, Walbro 255, stock turbo, recirc bov, ISIS 3" blast pipes with 3" test pipe.
The other day after having filled up my gas tank, I decided to drift around in a parking lot. After I was all done I decided to do a little pull and realized that as soon as I started to build boost around 3500rpm-4000 my motor felt like it was hitting fuel cut and attempting to build back up, kinda like what it feels like when you try to accelerate from a standstill in a high gear. The car won't sputter as bad if I ease into boost but if I go into it at WOT I feel like I'm bogging. Also, idle is a bit sporadic as in sometimes when I approach a stop, RPMs will dip down to 300rpm or lower but will go back up immediately. I checked and my plugs and coil pack #3 have white residue on them which leads me to believe I'm experiencing lean conditions, so maybe a fuel delivery issue? I've since changed out the plugs and cleaned the coil pack and will be checking my fuel filter. In the meantime, does anyone have any insight? Car will not always start first key turn, but I blame it on the shrunken battery and cold weather. I can definitely hear the fuel pump priming though. |
Man w/ CTSV & a Car Seat
Since you said it happened while you're drifting, check the fender harnesses. Tire might have rubbed them out if they have not been relocated.
If thats good, my guess would be a boost leak. |
![]() Join Date: Aug 2009
![]() Feedback Score: 16 reviews
sounds like you have a VAC leak of some sort, Fuel pressure or Spark Plugs..
Check Out My S13 Build |
#5 |
![]() Join Date: Mar 2013
if it was a vacuum leak it would be rich, not lean. coilpack or sparkplug would be my guess. check the gap on your sparkplugs too.
My Build |
#6 |
#8 | |
This guy needs to invest in a Wideband. Sure makes your life easy when diagnosing problems, and an extra layer of security. |
#9 | |
![]() Join Date: Jan 2013
No offense, just letting you know and so others don't read that and get confused. The solved problem proves that it was a giant ass vacuum leak. lol |
#10 |
Also check the gap on the plugs. If the car hadnt been romped in much prior to you doing the drifty shenanigans you may have opened up the gap on the plugs causing a spark blowout in boost. Could also be an over boost situation. All the sudden heat could have nuked a vacuum line to the wastegate. Ideally if you have a boost gauge in the car monitor the levels. If boost levels are stock or close to it throw some plugs in it and gap them down to .028-.030. Go from there
#11 |
Thanks guys. I bought BKR7E's and have them gapped down to .030 right now but a fellow SR owner suggested I get BKR6E's and gap them down to .025 to see if that will make a difference.
#15 | |
#16 |
in the downpipe, somewhere near the firewall so you can run the wires to the cabin. it has to be around 2 feet from the head. if you get the AEM, it has specific fitment instructions in the leaflet. (the instructions are also on their website in pdf's)
My Build |
#17 | |
Once you get you a wideband and assuming your setup is stock-ish, get a AEM Tru-Boost controller and crank that boost up! I was running 17-18psi on factory fuel support with 10.9 afrs, all the way to redline. 10.9 is actually still very safe, anything past 11.5 is to lean. The boost controller really brings the car to life. Did the same thing to my buddies SR. The T25 cant flow more than 10psi at 7.5k RPMs. So you can hit 17psi at 3k, the boost falls perfectly and you maintain perfect AFR's. |
#18 |
Be sure to check you FPR as well. I just replaced one on my friends KA-T. He was having the same exact problems you are.
#19 |
Turns out the piping that goes down into the SMIC had come off the coupler completely. Don't know how I missed that... But on the bright side I'm able to get sideways again
#20 |
you are wrong. i'll prove it to you :
1. the air coming OUT of the leak, is pressurised. so its coming out, with the force of 1 bar, rather than weakly sucked in by the engine 2. the sputtering was happening under boost, which means again, that the pressurized air was lost, otherwise it would happen on cruising etc. too. come on, that's basic stuff. also, it's happened to me and i've got a wideband...on cruising the AFR was almost identical to normal, when boosting, the car would hit full rich.
My Build |
#21 | |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
Key word is "under boost"
