Old 04-21-2014, 12:50 PM   #1
Stayabovethelaw
Stayabovethelaw's Avatar
Trader Rating: (59)
Stayabovethelaw is an unknown quantity at this point
Feedback Score: 59 reviews
S13 Coupe Part out !! Momo, megan, isis, pbm, bunch of stuff
Parts galore
xs power used few lil dents on bottom from mounts no leaks/cracks ------ $90 intercooler #2 bought from raw brokerage brand new ------- $175
ISIS aluminum radiator used with rb25 in s13 with 6an bung welded into for turbo water return----- $130
custom aluminum skid plate------ SOLDDDD
momo steering wheel hub----- SOLDDDDDD
momo steering wheel----- SOLDDDDD
momo seat------- ----$350
fal twin pusher fans which go into your rad support great for clearance----- $225
5 lug conversion front hubs have arp extended studs ----- solddddd
front powder coated knuckles----- $100
rear knuckles----- $50
fresh cleaned and powder coated rear sub frame with solid bushings---- SOLDDDDD
fresh cleaned and powder coated front sub frame drilled for rb motor swap use but will also work with ka/sr still also------ SOLDDDD
powder coated blue front lower control arms with moog ball joints----- SOLDDDDD
megan tension rods---- SOLDDDDDD
megan inner / outer tie rods--- SOLDDDD
powder coated front megan sway bar----- SOLDDDDD
megan rear upper control arms---- SOLDDDD
megan rear traction bars---- $85
megan rear toe arms--- $75
megan rear lower support bar---- SOLDDDD
rear lower control arms---- $65
NEW rear calipers powder coated with hawk pads--- $85
used rear s13 calipers with pads---- $40
3 inch straight pipe exhaust---- ---$100 DOWN PIPE BACK
NEW braided lines 240sx to 300zx calipers----- $50
240sx braided rear brake lines----- soldddd
apexi turbo timer---- soldddd
metal battery box for trunk or wherever--- SOLDDDDD
PBM adjustable shift knob---- soldddddd
PBM drift button for e brake---- solddddd
PBM hood spacers gold color----- solddddd
TAKATA Harnesses----- SOLDDDD
S13 center console with coin holder---- $60
Grey suede glove box--- $25
S13 6 bolt axles 2 used $50, 2 new $100, and one more used one $25
s13 ebrake handle and cabkes---- $65
s13 gas tank---- $60
1 1/16 brake master---- solddddd
Will add more items later still----- more pics coming soon also….
If you need them asap msg me
Any questions you can msg me 646 358 9694
Thanks,
Eddie
INSTAGRAM
------->>>> @StayAboveTheLaw <<<<--------
Stayabovethelaw is offline   Reply With Quote
