Old 06-19-2004, 04:05 PM   #1
mastaflash05
mastaflash05 is just really nicemastaflash05 is just really nicemastaflash05 is just really nicemastaflash05 is just really nicemastaflash05 is just really nicemastaflash05 is just really nicemastaflash05 is just really nicemastaflash05 is just really nicemastaflash05 is just really nicemastaflash05 is just really nice
Send a message via AIM to mastaflash05
buying VLSD - what to check on it.
im about to pick up a hicas VLSD from a local guy with shafts for 200$. - is that a goo price? - since i will be able to look at it in person before buying it, i would like to check it out to make sure it is good, and actually is a LSD. how can i be absolutly sure it is a vlsd? the orange sticker? if i pull the cover off what should i look for?
any help is appreciated.
mastaflash05 is offline   Reply With Quote
Old 06-20-2004, 06:17 PM   #2
Dutchmalmiss
Dutchmalmiss's Avatar
Dutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfection
Send a message via AIM to Dutchmalmiss
if both sides spin the same direction
Pignose, biaaatch.
Dutchmalmiss is offline   Reply With Quote
Old 06-20-2004, 06:26 PM   #3
citizen
citizen's Avatar
citizen is making a name for him/her selfcitizen is making a name for him/her selfcitizen is making a name for him/her self
Send a message via AIM to citizen
make sure there is little or no play in the side shafts
citizen is offline   Reply With Quote
Old 06-20-2004, 06:48 PM   #4
240Driver39
240Driver39 is making a name for him/her self240Driver39 is making a name for him/her self
Send a message via AIM to 240Driver39
the orange sticker is one way. Also the rear cover will have a bulge out at the bottom because of its larger fluid capacity. u can also tell from the output shafts.
1990 240sx 5spd fastback
240Driver39 is offline   Reply With Quote
Old 06-20-2004, 06:54 PM   #5
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
id say thats a very good deal.
I was going to, but I can not think of a sig less than 75 characters.
mjjstang is offline   Reply With Quote
Old 06-20-2004, 09:19 PM   #6
mastaflash05
i bought it tonight, he spun where the shaft goes in and both output shafts go in the same direction. how should i check for play? i took his word for it that it was good and real. he said if i find that its bad or anythinghe will buy it back. he's a real cool guy.
i might buy a practicly brand new greddy exhaust from him for $350-400.
Old 06-20-2004, 10:35 PM   #7
citizen
citizen's Avatar
when you spin it if there is rotational play before it starts moving the other stuff, i.e. if you spin the input shaft and it has some play before it starts to spin the output shafts means the gears are worn down bad.
Old 06-21-2004, 12:01 AM   #8
NinjaGaiden
NinjaGaiden's Avatar
NinjaGaiden is an unknown quantity at this point
did he tell you how many miles were on it? VLSDs are not repairable.
try to turn the output shafts in differnet directions. if u can, then its not a VLSD, or its worn out. when i tried to turn mine in different directions it was very difficult.
enjoy ur VLSD. its very nice compared to open diff, specially on u-turns =D
NinjaGaiden is offline   Reply With Quote
Old 06-21-2004, 07:51 PM   #9
mastaflash05
theres not much play at all. you can turn it just a small amount before the output shafts start to move. i do not know how many miles are on the diff. but it is prety clean. idk. hopefuly i can get alot of good use from it.
so will this make me be able to be at a stoped position, and whip the car around 180* from a standstill?? i want to be able to do that; it just looks cool.
