Old 04-25-2014, 09:54 AM   #1
dillondet
dillondet's Avatar
dillondet is an unknown quantity at this point
S14 KA24DE issues
So recently I've purchased my first 1995 s14 with a KA24DE fully stock DOHC. My issue is that what i've recently discovered when on the freeway, my cluster is glitched btw and it's off by 30-50 mph. im assuming the tachometer isnt working properly as well. As i was going on the freeway, assuming im about 50-55 mph on the very right lane, i've tried pressing more on the gas pedal, trying to gain more speed, but as soon as it gets to a point, it stops, my car "lunges" in a way and doesnt allow to go any faster, it seems as if i try to apply more gas to go faster, it cuts off and does not allow me to go any faster beyond 50-55 mph im assuming that's how fast i was going. Everything seems to work fine, my assumption for the reason why my cluster is glitched is because my car has an s13 speed sensor on an s14 transmission and ecu? I've recently researched as to why the cluster was being like that and I've came to a conclusion that the s13 speed sensor does not work with the s14, and it might cause the reason as to why my car wont go any faster. I'm fairly new to my car, i'm trying to learn as much as I can. But so far ive been leaning towards the conclusion it has something to do with the MAF? I'm just guessing by now. it would be great if someone could enlighten me please. tell me what i should do, what i should check.
dillondet is offline   Reply With Quote
Old 04-25-2014, 12:54 PM   #2
jedi03
Can you redline the car in other gears? If it doesnt go above 2500 most likely is maf
Old 04-25-2014, 01:01 PM   #3
dillondet
dillondet's Avatar
i cant redline on 5th gear im sure of that, but my cluster doesnt work, im assuming the tach is off too.
Old 04-30-2014, 07:55 PM   #4
Legend1515
Legend1515 is an unknown quantity at this point
speed sensor maybe
Legend1515 is offline   Reply With Quote
Old 04-30-2014, 07:56 PM   #5
Legend1515
or rev limiter reacting to the broken tach
Old 05-01-2014, 01:13 PM   #6
dillondet
dillondet's Avatar
Might be the chance, thanks for the info!
